What's a '62 Standard Ensign Deluxe dashboard look like?
MartinC
PostPosted: Wed Jul 29, 2009 11:28 am    Post subject: What's a '62 Standard Ensign Deluxe dashboard look like? Reply with quote
Okay, an odd question I know, but does anyone know what the instrument cluster should look like in one of the late Deluxe Ensigns?
The one in mine is nothing like a Vanguard item but is just 3 clocks in a flat plate. Doesn't look right.
1937 Standard Flying Twelve
1942 Bedford OYD
1954 Hillman Minx
1956 Austin A30
1957 Vauxhall Victor Super
1962 Car Cruiser Carissima caravan
PostPosted: Wed Jul 29, 2009 11:48 am    Post subject: Reply with quote
It was detrimmed Vanguard and a reintroduction for 61/62 season only after it was deleted so may have had a basic dash?
Any pics?
Rover P2
Morris Mini Traveller Mk2
MartinC
PostPosted: Wed Jul 29, 2009 12:01 pm    Post subject: Reply with quote
Even if it is right, I don't like it! Maybe I'll do it gold/bronze or something.
1942 Bedford OYD
1954 Hillman Minx
1956 Austin A30
Keef
PostPosted: Wed Jul 29, 2009 12:22 pm    Post subject: Reply with quote
Doesn't seem to be many pics about. This anything like what you expect? :-
http://www.standardmotorclub.org.uk/images/vanguards/sportsman/P1010006.JPG
Lots of external shots here :-
http://www.flickr.com/groups/standardmotorcompany/
Keef - Sheerness Kent UK
MartinC
PostPosted: Wed Jul 29, 2009 12:56 pm    Post subject: Reply with quote
Yes that's the usual Vanguard style dash
1942 Bedford OYD
1954 Hillman Minx
1956 Austin A30
PostPosted: Wed Jul 29, 2009 3:11 pm    Post subject: Reply with quote
I like this. Very rare
and For Sale
http://www.carandclassic.co.uk/car/C54518?pt=pf
PostPosted: Wed Jul 29, 2009 4:04 pm    Post subject: Reply with quote
I think it is correct. I have a drawing of the 1960/61 Vanguard Six panel and
whilst the earlier versions of it and the Ensign had a 180 degree speedo with minor instuments below, the later Vanguard has the same panel shape as you. It also has a central circular speedo but has four minor instruments grouped one above the other each side of the speedo.
MartinC
PostPosted: Wed Jul 29, 2009 4:18 pm    Post subject: Reply with quote
Thanks Peter, yes I think so too.
Spent the day dismantling it and can tell it's a factory job.
Couldn't get the speedo apart. Got the bezel off but the glass was well and truly stuck. Sprayed WD40 inside and the needle seemed to be bouncing freely. Unfortunately on the road test it was exactly the same Sad
Also, it now looks like this:
Which suits the red interior much better I think.
1942 Bedford OYD
1954 Hillman Minx
1956 Austin A30
PostPosted: Thu Jul 30, 2009 10:34 am    Post subject: Reply with quote
Now that I've seen a picture of your speedo I see that my advice on the sticking was all wrong. Your pointer is plastic and not bendable. Probably isn't the cause of the sticking anyway.
PostPosted: Thu Jul 30, 2009 12:13 pm    Post subject: Reply with quote
The magnet disk at the rear of speedo face sometimes gets dust/corrosion speck on it - try WD40. make sure the cable is not kinked/badly routed or loose though.
I agree the metal dash plate does not look right - maybe original finish eg vynil/fake woodgrain came off - some cars had anodised finish with various pattern. The last Ensigns are very rare now as eveyone waiting for the new 2000 Triumph
Rover P2
