Hillman Hunter torque figures req'd
john-saab
PostPosted: Sat Aug 01, 2009 7:27 pm    Post subject: Hillman Hunter torque figures req'd Reply with quote
I'm about to make a start on replacing the cylinder head gasket on the 1500cc iron headed Hillman Hunter..i am waiting for a Manual (ebay) but it's not arrived and i want to make a start.
Does anyone have the tightning sequence and torque settings for the cylinder head on this car ?
Also looking for the sequence and gap size for the rocker arm/pushrod.
Cheers.
Rust Junky & oil addict.
PostPosted: Sat Aug 01, 2009 7:51 pm    Post subject: Reply with quote
If it's the same as the 1500 and 1600 iron head engines from Minx and Super Minx ranges then the torque is 45-48 lb-ft
as follows:
Front--7--5--1--4--10 Rear
Front--9--3--2--6--8 Rear
--------------Ports
Clearances are 12thou inlet 14 thou exhaust.
Just turn the engine until the valve you want to adjust is fully open then give it one complete 360 degree rotation and you are guaranteed to be on the back side of the cam.
john-saab
PostPosted: Sat Aug 01, 2009 7:55 pm    Post subject: Reply with quote
Thanks Peter. Do you know the pushrod gap size..and the sequence for adjusting?
PostPosted: Sat Aug 01, 2009 8:01 pm    Post subject: Reply with quote
Sorry. see above.
john-saab
PostPosted: Sat Aug 01, 2009 8:08 pm    Post subject: Reply with quote
Thanks again Peter.
bob2
PostPosted: Wed Aug 05, 2009 10:18 am    Post subject: Reply with quote
Hi John saab
Have you done it already or still need the info, I can check it up on the manual I have in that case!!
Hadnt seen ur post before as I was on hols.
