But what are they????
PostPosted: Mon Aug 17, 2009 9:18 am    Post subject: But what are they???? Reply with quote
Does anyone recognise these??? are they car related or not, maybe someone knows??
PostPosted: Mon Aug 17, 2009 10:32 am    Post subject: Reply with quote
They look like oilers for a Veteran or Edwardian car. Usually affixed to the dashboard, they were filled with oil which was then piped to where it was needed- a total loss system. The 'flip over' brass tops cut the oil flow completely for when the vehicle was stopped. The knurled tops (when the flip-over was upright) controlled the oil flow from one drop every few minutes to about a drip per second. A certain skill was required to make sure sufficient oil was being dripped to the part needing lubrication.
PostPosted: Mon Aug 17, 2009 6:36 pm    Post subject: Reply with quote
Yep, just normal oilers by the look. I have them on my lathe.
They should have a wick in them.
They came from little to big, depentant on the item ie a shaft being lubricated, alot of engines have them.
What have you got them for?
dclf1947
PostPosted: Tue Aug 18, 2009 1:49 pm    Post subject: Reply with quote
These are classed as "wine Glass" drip oilers because of the shape of the glass. There is no wick inside them the "lever" on the top opens a needle valve and the number of drops per minute is adjusted by screwing the knurled nut below up or down. Many stationary engines them and they are very collectable selling for very good prices on e-bay.
I show an example below fitted to a Tangye 1 3/4 Gas engine I had.
[img][/img]
PostPosted: Tue Aug 18, 2009 3:20 pm    Post subject: Reply with quote
I remember those from my early years working with Winding Engines at the coal mine.
Still available today.
http://www.steamfittings.co.uk/asp/components_subcats.asp?CatID=35
PostPosted: Tue Aug 18, 2009 4:37 pm    Post subject: Reply with quote
Mine have a wick down the centre on the lathe.
PostPosted: Tue Aug 18, 2009 6:18 pm    Post subject: Reply with quote
Thanks for the id's gents, they came with some other stuff a while back and I've been scratching my head over them ever since Smile
