Classic car audio
Goto page Previous  1, 2
PostPosted: Sat Dec 13, 2008 11:48 pm    Post subject: Reply with quote
Hi Rich,
Until I got fed up skinning my knuckes when gear changing I had an earlier HMV Radiomobile...
http://www.jag-lovers.com/saloons/ss/ss10.jpg
and it worked remarkably well on an under wing aerial.
You probably won't have the length under your front wings but it might fit if it were bent into an inverted "L" or "U"
http://www.jag-lovers.org/snaps/snap_view.php3?id=1117063708
steveglazier
PostPosted: Wed Aug 12, 2009 6:08 pm    Post subject: Reply with quote
Another go at this topic, What sizes speakers would have been used in a 1959 ford 100e. Would it have been one single 4 ohm speaker
or a 8 ohm. I have a 1959 ford radio but now speakers (radio does work Tried it on a 4ohm modern speaker, But the volume seem's a bit on the low side
Cheers Steve
PostPosted: Wed Aug 12, 2009 7:44 pm    Post subject: Reply with quote
Older radios used 8 or 16Ω speakers - 2 matching 4Ω speakers in series (I think or it parallel?) will equal 8Ω
Rover P2
Morris Mini Traveller Mk2
Rich5ltr
PostPosted: Wed Aug 12, 2009 8:04 pm    Post subject: Reply with quote
Can't comment on the speakers because the internals of my radio were modernised but here's my finished job
PostPosted: Mon Aug 17, 2009 2:15 pm    Post subject: Reply with quote
Here we go; impedence is measured in ohms at 1khzs and represented by z.
Speakers in series are simply added together like so, zt = z1 + z2 + and so on.
Speakers in parallel are represented by the equation, 1/zt = 1/z1 + 1/z2 + and so on.
So 2 x 4ohm speakers in parallel = ¼ + ¼ = ½ now reciprocate = 2ohms
And 3 x 4ohm speakers in parallel = ¼ + ¼ + ¼ = ¾ reciprocate = 4/3 or 1 1/3 ohms. The most power out of a speaker is when the speaker impedence matches the internal impedence of the amplifier, this is known as impedence matching.
Got it?
Idea
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Mon Aug 17, 2009 4:03 pm    Post subject: Reply with quote
Flicking through a 1951 copy of The AA handbook the other evening, it reminded me of the need (back then) to have a license for a car wireless - when did that cease to be the case???
PostPosted: Mon Aug 17, 2009 9:04 pm    Post subject: Reply with quote
About 1970 although most ignored by then
Rover P2
PostPosted: Tue Aug 18, 2009 1:55 pm    Post subject: Reply with quote
I would guess that it was the same time they dropped the domestic Radio licence.
PostPosted: Wed Aug 19, 2009 10:24 am    Post subject: Reply with quote
If you have a radio in a shop or other public area you have to pay around £200 to the performing rights people. Somehow I do not believe the money gets to any of the artists, why don't the authorities just call it a licence or Radio Tax.
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Wed Aug 19, 2009 10:54 am    Post subject: Reply with quote
Same applies in Oz, however a friend of mine solved the problem by installing a notice in his shop which read "Please Note- The Radio in this shop is for the staff only. Customers and members of the public must refrain from listening to it."
Page 2 of 2
