Ford 10 hp cam removal
7cylinderHEMI
PostPosted: Thu Oct 29, 2009 11:22 am    Post subject: Ford 10 hp cam removal Reply with quote
taking the cam out of my 10hp how do you get dizzy drive out?
Greg
PostPosted: Thu Oct 29, 2009 2:58 pm    Post subject: Reply with quote
Behind the valvegear coverplate, you will see a small hole into which you insert, or screw in a threaded rod or small screw,( can't remember the exact size) then allowing you to pull out a sort of bung that locks the shaft in place.
Hope this helps, unfortunately I have recently moved and all workshop manuals are in storage somewhere, ........I hope Smile
the fun part is lining up the distributor shaft when re-fitting.
All the best,
Greg
7cylinderHEMI
PostPosted: Fri Oct 30, 2009 3:01 am    Post subject: Reply with quote
thanks Greg we have done that but it still wont budge ,the engine was running recently but must have nipped up on shaft ,gunna soak it and have another go ,thanks again ........Rod
7cylinderHEMI
PostPosted: Mon Nov 02, 2009 11:35 am    Post subject: Reply with quote
wd40 and a brass drift did the trick ,must have had a build up around it ,it sort of fell out when tapped ,
