RogerL
Posted: Tue Nov 10, 2009 3:39 pm Post subject: Morris Minor Lowlight Screen Chromes |
I am putting the finishing touches to a 1950 Morris Minor lowlight tourer. It’s more or less done except for refitting the screen chromes, which I just can’t back in. There seems no way the wide ‘U’ shaped chrome can get a purchase in the rubber moulding. Does any one have any words of wisdom?
Roger |
Posted: Tue Nov 10, 2009 5:19 pm Post subject: |
How about spraying the moulding with some rubber lubricant _________________ ROVER
One of Britain's Fine Cars |
RogerL
Posted: Tue Nov 10, 2009 6:09 pm Post subject: |
The problem isn’t that I can’t get the chrome into the rubber moulding, it’s that it won’t stay there. The chrome is shaped like an elongated ‘U’ with nothing to stop is slipping out. The shape is a bit like; [ . The curved corners are particularly difficult.
Roger |
peppiB
Posted: Tue Nov 10, 2009 8:11 pm Post subject: |
Do you have the correct tool to put the trim in? It is very difficult to do without one |
Brian M
bob2
Posted: Wed Nov 11, 2009 11:42 am Post subject: |
just used one of those to fit the insert on my hunter screens and it went in without any difficulties on the rear, the front rubber was a used one not new like the rear and was a bit more difficult but still managed it in around 20-30 minutes!!
great tool to make life a bit easier!! |
dclf1947
Joined: 23 Nov 2007 Posts: 107 Location: Laoag City, Philippines
Posted: Wed Nov 11, 2009 1:06 pm Post subject: |
Notice on the description of the tool it states "not suitable for metal filler strips". RogelL says his is chrome. All the same I would think that Frost probably has an alternative that maybe suitable for metal filler strips. |
arossco
Posted: Wed Nov 11, 2009 10:29 pm Post subject: |
My '56 Cresta has clips which fit around the circumference of the windscreen rubber - in the middle of the rubber - to hold on the chrome trim.
These clips fit into a central groove and another thin strip of rubber fits on top to fill the gap and hold them in place.
The chrome trim has the same kind of profile as yours and just snaps on to the above clips.
Hope this makes sense - if not I could try and draw a diagram ...
Ross |
RogerL
Posted: Thu Nov 12, 2009 11:34 am Post subject: |
Thank you all for the suggestions. Unfortunately, the Frost tool, as someone has mentioned, is not intended for metal strips and Frost has no othert offering. Does anyone know where a suitable tool may be found? |
Carcruiser
Joined: 07 Dec 2007 Posts: 89 Location: Worcestershire
Posted: Sat Jan 09, 2010 10:22 am Post subject: |
Hi,
I don't think theres a suitable tool for doing this. The workshop manual reccomends fitting a piece of string in the channel and then pulling the string out away from the chrome as you push the chrome in. I have done it this way and it does work to a certain extent! I think some of the problem is new screen rubbers not being quite grippy enough to hold it.
One side went in fine for me, but the other side one corner kept popping out so I cheated and glued it in, clamping it in place with a G clamp and a piece of wood round the screen pillar overnight. That worked! |
