vintage norton Guest
Posted: Fri Mar 10, 2006 12:42 pm Post subject: Steering box help required |
| I need to replace the steering box on my E83W. The bit I am not sure about is separating the steering column from the steering box. I am sure a number of you will have done this in the past so any advice would be greatly appreciated. |
buzzy bee Guest
Posted: Wed Jan 10, 2007 12:33 am Post subject: |
The casting on my steering box has boken in that weak spot, What do the earlier boxes look like as they have a different casting don't they?
Will the earlier fordson ones fit the E83W?
admin
Posted: Wed Jan 10, 2007 8:41 am Post subject: |
I've got an earlier steering box buried away somewhere, with a cast iron mounting bracket. From memory the shape of it is different so I doubt it'd bolt straight onto a later truck, but could be wrong on that!
Rick |
buzzy bee Guest
Posted: Wed Jan 10, 2007 9:40 am Post subject: |
| Ok no probs, worth asking! |
