scott_budds
Posted: Tue Jan 05, 2010 10:16 pm Post subject: Small paint gun from machine mart |
Hi all
Ive never done any paint spraying but need a small spray gun to paint my wheels. I also will need to do some stone cchips and small areas of my Lotus body work at some point. Ive got a fairly decent compressor and was looking at this little gun in machine mart.
http://www.machinemart.co.uk/shop/product/details/tg2-professional-touch-up-gun/path/spray-guns-spraying-equipment-air-brushes
would something like this be any good? Or is it better to get a normal size one?
Many thanks
Buddsy _________________ Im looking for an Elan plus 2 for my next resto project...if you see one think of me please!! |
peppiB
scott_budds
Posted: Tue Jan 05, 2010 10:34 pm Post subject: |
is it better to get a big one like that even for the small areas? Also gravity fed or not whats the difference?
Posted: Tue Jan 05, 2010 11:46 pm Post subject: |
I have one of the small guns and they are great for small touch is less paint is wasted cleaning and you can deal with very small areas provided light thin coats are used - very much like using an aerosol.
A proper gun is needed though for panel work _________________ Rover P2
Dirty Habit
Posted: Tue Jan 05, 2010 11:49 pm Post subject: |
I have had one for years. Simple little gun that is great for painting small parts. _________________ 1964 International Harvester |
clascar
Posted: Sat Jan 09, 2010 5:03 pm Post subject: |
I use an airbrush for small areas and parts, I got fed up of buying aerosols. You can buy air packs to power them or I use an electric tyre pump or I have made an adaptor for my compressor.
I found the first gun mentioned with the trigger on the top awkward to use.
[img[/img][code [/code] _________________ When I exhibit a car I get the Shudders. People queue up to tell me.
You should have done that, you should have done this. Ray |
scott_budds
Posted: Fri Jan 22, 2010 2:15 pm Post subject: |
OK Stupid question but what can I use as a thinners? Do I use whitspirit etc?
Posted: Fri Jan 22, 2010 2:46 pm Post subject: |
Where ever you get you paint from will sell you the right thinners for the paint, its also worth geting a 5 litre can of cheap (gunwash) thinners to clean up afterwards.
scott_budds
Posted: Sat Jan 23, 2010 10:45 am Post subject: |
Ok so I bought some POR15 engine enamel I am using to paint the centres of my alloy wheels. It says you can thin not more than 20% so was wondering what I should use? _________________ Im looking for an Elan plus 2 for my next resto project...if you see one think of me please!! |
clascar
Posted: Sat Jan 23, 2010 9:03 pm Post subject: |
Frosts do POR 15 solvent £10.50 a quart. They recommend 20% dilution. _________________ When I exhibit a car I get the Shudders. People queue up to tell me.
