Frustration!
PostPosted: Tue Jan 12, 2010 6:54 pm    Post subject: Frustration! Reply with quote
Somewhere on this Forum or the Main Site I saw mention of a Triumph Gloria, but I can't remember where.
It prompts memory of perhaps my most frustrating job as an apprentice.
A customer came in with his Gloria one day saying his rear seat cushion had collapsed. Examination determined that it was inflatable and fitted with a Schrader Valve.
I was designated to rectify it. Blowing it up did not work so I took the cushion apart. Inside was literally about 40 or 50 feet of tubing of about 2 inch diameter with obviously a puncture. Working my way along its length a few inches at a time was bad enough, but perseverance paid off! Mending the puncture, once found was a doddle. Getting all that tubing back inside with reasonable shape to the cushion took me about two and a half hours! Frustrated? I was ****** ***!
What is your most frustrating maintenance job?
Jim.
PostPosted: Tue Jan 12, 2010 8:05 pm    Post subject: Reply with quote
Getting all the balls and springs back in my syncho hubs was a bit frustrating until I learned (the hard way) to wrap the hubs in a cloth so that when they do jump out they don't go flying the furthest corners of the garage.
Puting my diff. back in the axle was also very frustrating. It had to do it from underneath with me lying on my back but I just wasn't strongth enough to lift it back into place and it wouldn't sit in the little pan of my trolley jack. Many attempts were made before I got totally exhausted and on quite a few goes I would tear the circular paper gasket and have to make another one.
Fortunately I was rescued by the chance visit of a friend who was able to relieve me of some of the weight by pulling on a rope passed through the boot.
PostPosted: Tue Jan 12, 2010 9:58 pm    Post subject: Reply with quote
The pins in the early pre load system on the C1879 penny was a bit testing!
Nic Jarman
PostPosted: Sun Jan 17, 2010 9:56 pm    Post subject: Reply with quote
stripping and rebuilding Shimano STI shifters.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Mon Jan 18, 2010 3:17 am    Post subject: Reply with quote
Trying to stop the oil leak at the Lucas Dynastart on a 1928 flatnose Morris Cowley. It has a horrible pressed tin cover that distorts while you look at it!
Keith
PostPosted: Mon Jan 18, 2010 9:02 am    Post subject: Reply with quote
I had to do this job yesterday on the Morris 8, and was thinking about your post, the workshop manual tells you to slip some old feeler gauges between the balls and the gear, I didn't even try this ! came up with my own method which worked first time:
First of all I put the springs and balls in with large blobs of grease to "stick the springs in place and the balls to the springs.
I then put a jubilee clip around the balls and tightened it up so that the balls were about 2/3 in the hub, and then slid the gear up.
Worked a treat Very Happy
PostPosted: Mon Jan 18, 2010 10:01 am    Post subject: Reply with quote
Well done Dave,
That certainly looks like a good method. (and makes me feel like a wally Confused )
I think you shouldn't be allowed to post it in this thread as it has clearly removed the element of frustration from the job. Evil or Very Mad
Peter Sad Very Happy Wink
PostPosted: Mon Jan 18, 2010 7:32 pm    Post subject: Reply with quote
For most jobs there is always a short cut or someone comes up with a brilliant idea. Maybe we should have a separate section for this kind of thing.We all have our own shortcuts and ideas which could be useful to others who are not too mechanically minded.
The Clan Chieftain
