dalbuie
Posted: Tue Apr 27, 2010 5:23 pm Post subject: Prop Shafts |
After last year driving around with a top speed of 45 in my Chevy Pickup I've fitted a 1960 diff (straight 10 bolt swap) which should give me a 50mph cruising speed this year
The only thing left to do is get the prop shaft remade with a 60's yoke at one end, the original at the other, and a new straight shaft in between with another 1/4 inch in length.
I have found a reasonably local prop-shaft maker in Bonnybridge but wondered if anyone had any other suppliers and any ballpark costs this could cost me.
Cheers |
Dirty Habit
Posted: Tue Apr 27, 2010 8:47 pm Post subject: |
Is your problem that the U-J's are different sizes ? If so you can get conversion joint........ for around $25-$40
This is a great site for anything to do with American drive shafts and the link takes you to the page with the conversion joints
http://www.dennysdriveshaft.com/c130_universal_joints.html _________________ 1964 International Harvester |
dalbuie
Posted: Tue Apr 27, 2010 10:39 pm Post subject: |
Thanks, but the overall prop is now a bit short - and always had a bit of a buckle in it so a new one is needed. |
Joined: 16 Oct 2008 Posts: 1164 Location: Upper Swan, Western Australia
Posted: Wed Apr 28, 2010 1:53 pm Post subject: |
The most important thing to remember when modifying tailshafts is to get them accurately balanced after all the work has been completed! If you don't, it'll shake the car apart!
Keith |
dalbuie
Posted: Wed Apr 28, 2010 2:19 pm Post subject: |
Thanks Keith, that's the problem I have just now as the prop has a run out of 9mm when the recomendation is under 1
I've contacted http://www.driveshaftuk.com/ and they estimate £150 delivered which sounds reasonable to me. |
