Petrol cans
Bayliss Thomas
PostPosted: Fri May 14, 2010 12:54 pm    Post subject: Petrol cans Reply with quote
Just purchased an old world 2 gall petrol can for use on my cars running board. The interior of the can has some minor rust spots, nothing over dramatic but I have rinsed can out with an drop of petrol now. Is the rust spotting an disaster or can I still use can for spare petrol? Can has no leaks.
stuchamp
PostPosted: Fri May 14, 2010 1:57 pm    Post subject: Reply with quote
I had a one gallon can that had tarnish and a little rust. Put a cup of silica sand in it and took it to a body shop where they put it on their paint can shaker for about 20 minutes. Looks like new inside now. Very Happy
PostPosted: Fri May 14, 2010 3:37 pm    Post subject: Reply with quote
I bought an old petrol can to go on the Talbot's running boards so I put some sand in it and gave it a good shake, it looked nice and clean but it started leaking a few days later. Sad
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
mid
PostPosted: Sat May 15, 2010 9:15 am    Post subject: Reply with quote
I assume that you could coat the inside similar to an actual fuel tank using something like the Frost product?
http://www.frost.co.uk/item_Detail.asp?productID=8232&frostProductName=Fuel%20Tank%20Sealer%20%28US%20Quart,%20946ml%29
never tried it myself but have heard good things...
Rusty
PostPosted: Sun May 16, 2010 9:40 am    Post subject: Reply with quote
That sort of stuff works well !
My brother uses simmilar stuff on motorcycle fuel tanks. It has to be chemically cleaned with some sort of acid that comes with the kit but works a treat. I recon it would work on your Jerry can !
" Not cheap though !"
michael1703
PostPosted: Sun May 16, 2010 9:53 am    Post subject: Reply with quote
ive done similar except i used nuts and bolts and ball bearings to get rid of the loose rust
Salopian
PostPosted: Sun May 16, 2010 10:33 am    Post subject: Reply with quote
I always thought these cans were tinned metal and have found they rust like the proverbial when this coating has gone. I'd use one of the tank sealers suggested as I have treated mine with success. They will leak round the bottom seam where the turned over lip wears off.
Don't forget the pre war ones are dated (month & year) underneath.
Jonathan Butler
Bayliss Thomas
PostPosted: Mon May 17, 2010 10:10 am    Post subject: Reply with quote
Great tips, thanks to one and all Very Happy
