Rover P4 1955 Six Cylinder
Alextriumphfan
PostPosted: Wed May 19, 2010 11:31 am    Post subject: Rover P4 1955 Six Cylinder Reply with quote
Hi,
Posting for a friend.
Car starts and runs for a while then starts to falter. Backing off gas then it goes OK again. Changed fuel pump and filter but still not right.
Any ideas folks???
Anything specific to this model???
Thanks
PostPosted: Wed May 19, 2010 1:44 pm    Post subject: Reply with quote
Carb jets clear?
PostPosted: Wed May 19, 2010 2:20 pm    Post subject: Reply with quote
Could be a blocked petrol tank breather.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Wed May 19, 2010 7:49 pm    Post subject: Reply with quote
Is glass sediment bowl clean?
Rover P2
Morris Mini Traveller Mk2
PostPosted: Wed May 19, 2010 10:30 pm    Post subject: Reply with quote
This can be a symptom of water droplets in the carb. As fuel flow (demand) increases and other jets come into use water droplets can be "sucked" (not technically correct terminology) onto the jet, effectively blocking it until the demand falls. The surface tension of water prevents it passing through most jets in a carb. Constant depression carbs excepted, which can sometimes be cleared by revving and momentarily blocking the air intake.
michael1703
PostPosted: Thu May 20, 2010 9:17 pm    Post subject: Reply with quote
air leak /running lean?
at idle, if you press the piston lifter plunger does it stall/rev/remain same ?
baconsdozen
PostPosted: Fri Jun 25, 2010 12:45 pm    Post subject: Reply with quote
I had the same problem on a P5B rover,I cleaned out the filters and checked for air leaks,drained the tank and generally played about for hours with no luck.Finally I took the main fuel pipe off and after poking about with wire and blowing through with an air line managed to shift a load of crud and the car (touch wood) has run smoothly since.
I think the muck settled on one of the bends or a join and was compacted under high demand effectively sealing the pipe.
Best of luck anyway.
