michael1703
Posted: Thu Jul 01, 2010 8:09 pm Post subject: I'm thinking of selling this, what do you think its worth? |
Its a 1970 nsu super prinz 4l, its a 600cc twin, the engine has had new liners and piston rings,block skimmed,head gasket and a brand new solex carburettor.
It runs but needs a bigger main jet fitted as it was supplied with a small un. the air filter is quite corroded and will need some work to refurbish
the exhaust needs welding or replacement, the o/s/r wheel has more camber than the others so that needs investigating, the footbrake does not function, the handbrake works but i havent had a chance to get the drums off yet to see what is needed
it has dents and bits of trim missing but the body is good apart from the A post area which isnt too scary and the sills need welding too
i have driven it and all 4 gears are fine including reverse, electrical bits work, just a sidelight bulb needed and nobs for the radio, choke cable is broken
the interior is good but a bit smelly
bit of an oddball car so its hard to value, ive seen one on ebay in worse condition for £550 but havent seen any others for sale |
