Bayliss Thomas
Posted: Thu Jul 22, 2010 12:26 pm Post subject: Fireproofing cooking area? |
My Eccles has its cooker situated next to the wardrobe, under an crockery cupboard and on other side of cooker the sink unit, as standard set out in 1930. Only the crockery cupboard has any type of fire proof material in the form of an sheet of tin tacked to the underside of the cupboard, even this has had an hole cut into it and therefore renders it useless!
My cooker is an modern two burner with oven propane affair which I intend to use (I do have the old paraffin cooker which is display only). My question is I need to cover exposed 'at risk' board with some form of fire proof material, suggestions appreciated.  |
Uncle Alec
Posted: Thu Jul 22, 2010 1:48 pm Post subject: |
| I used Masterboard which I bought at B&Q. Easy to cut and drill; similar to asbestos but without added death. |
gillberry
Posted: Thu Jul 22, 2010 7:59 pm Post subject: |
we keep hearing about this caravan are you going to post pics?  |
Bayliss Thomas
Posted: Thu Jul 22, 2010 8:10 pm Post subject: |
Hi Gillberry, unfortunately I am unable to post pictures, but if I can email some to yourself or other forum member perhaps you may do the honours for me?
Thanks for tip Uncle Alec.  |
Dalek63
Posted: Thu Jul 22, 2010 8:16 pm Post subject: |
Polished ali with some insulation behind it does the trick and looks vintage, the ali reflects the heat very well. _________________ I can resist anything except temptation ! ( Oscar Wilde)
Bayliss Thomas
Posted: Thu Jul 22, 2010 8:20 pm Post subject: |
| Sounds like perfect solution, presume alli was used as original fire proofing. Anyhow I can easily get an sheet of that and glue some fibreglass insulation to the back of it. Thanks. |
Uncle Alec
Posted: Thu Jul 22, 2010 8:22 pm Post subject: |
| I should add that I faced the Masterboard with aluminium sheet. Eggs & bacon slide off a treat. |
gillberry
Posted: Thu Jul 22, 2010 8:23 pm Post subject: |
| will send you a pm with our email address |
Bayliss Thomas
Posted: Thu Jul 22, 2010 8:25 pm Post subject: |
| gillberry wrote: | | will send you a pm with our email address |
Thanks Gillberry, I shall post some exterior shots and then tomorrow take some interior shots to post off as well. |
gillberry
Posted: Thu Jul 22, 2010 9:47 pm Post subject: |
Pictures - she looks great
Swampthing
Joined: 02 Feb 2010 Posts: 107 Location: Market town of Melton Mowbray
Posted: Thu Jul 22, 2010 11:35 pm Post subject: |
lookin' good or what. ! _________________ Nobody saw me do it, you can't prove a thing!! |
Swampthing
Posted: Thu Jul 22, 2010 11:36 pm Post subject: |
HMK
Posted: Fri Jul 23, 2010 12:06 am Post subject: |
I agree, it is looking really good.......& all the more reason to say so TWICE, Swampthing  |
old van man
Posted: Fri Jul 23, 2010 3:57 pm Post subject: |
i agree a very nice Eccles, well done i bet that dark roof gets a bit warm on a hot summers day OVM |
