jvh100
Posted: Wed Jan 13, 2010 1:59 pm Post subject: Gas Mantles |
Hi All,
Having found that there is now a dire shortage of gas mantles for classic vans, I did a few searches on the internet and found a couple of sites which might be of help to those of you who also need them.
One site is selling No1 and No2 mantles at around £9 (Yes! Nine pounds each). They can be found here...
http://www.caravanparts.co.uk/index.php?cPath=67_230
Another site selling No1, No2, & No3 mantles at £3 each is here...
http://www.ebro-fishing.com/Gas_light_mantles.html
For those who want to buy in bulk (no small orders anymore), there is this company who sell a box of 20 for around £100 per box (inc vat)...
http://www.wilmond.co.uk/acatalog/Gas_Mantles.html
Hope you guys find this useful and can once more enjoy the gentle hiss of the gas lamps and the soft warm glow of the light.
Thanks for looking,
John. |
Dalek63
Posted: Wed Jan 13, 2010 2:12 pm Post subject: |
If you dont wish to pay what I think is excessive prices for mantles I have used very successfully in our Carlight and other caravans the mantles used on modern gas camping lamps. Just tie the string above the lugs on the gas light and make sure the mantle is central then light it. When it is lit the mantle goes hard and hey presto, you have a useable mantle for just a few pence.
cheers
George _________________ I can resist anything except temptation ! ( Oscar Wilde)
Uncle Alec
Posted: Wed Jan 13, 2010 3:05 pm Post subject: |
I have a fair few mantles if anyone's struggling. £1 each? Don't fancy posting them though. |
jvh100
Posted: Wed Jan 13, 2010 4:50 pm Post subject: gas Mantles |
Dalek63 wrote: | If you dont wish to pay what I think is excessive prices for mantles I have used very successfully in our Carlight and other caravans the mantles used on modern gas camping lamps. Just tie the string above the lugs on the gas light and make sure the mantle is central then light it. When it is lit the mantle goes hard and hey presto, you have a useable mantle for just a few pence.
cheers
George |
This might be DANGEROUS! The hard preformed mantles are designed in such a way that enough air gets INSIDE the mantle - both through the adjustable hole in the bunsen and via the gap between the mantle ring and ceramic burner. This allows the gas to burn properly with minimum carbon monoxide being produced and little or no flame on the outside of the mantle.
These mantles come in various sizes for a very good reason. Each size is designed to be used with a specific size jet (nozzle). Using the wrong size mantle for any particular jet results in inefficient burning of the gas. If enough air isn't mixed with the gas, carbon monoxide results!
Doing it your way may well result in insufficient burning of the gas and may possibly lead to carbon monoxide poisoning. I don't need to spell the consequences out.
If you wish to advocate using gas appliances in a manner which they were not designed to be used, you will have to accept resposibility for incidents and liability which results from people following your advice.
I just hope nobody will follow your advice or ends up in hospital as a consequence of doing so.
Please do NOT advocate using gas appliances in a manner which they were not designed to be used. It is utterly irresponsible.
John. |
Dalek63
Posted: Wed Jan 13, 2010 7:26 pm Post subject: |
well thats me told off good and propper !  _________________ I can resist anything except temptation ! ( Oscar Wilde)
jonbott
Posted: Wed Jan 13, 2010 7:47 pm Post subject: |
Dalek63 wrote: | well thats me told off good and propper !  |
ah damn we`ve done that
oh but we have a correct one for the van as a spare from ebay _________________ 2dogs:(
3 cats
1962 otten
1972 vw camper
1971 mini project
I must be mad!! |
Dalek63
Posted: Wed Jan 13, 2010 11:27 pm Post subject: |
I'm still not pursuaded by jvh100's telling off and am doing some digging on the net for some more info. _________________ I can resist anything except temptation ! ( Oscar Wilde)
Dalek63
Posted: Sat Sep 25, 2010 5:55 pm Post subject: |
Its been a while but a few other posts about mantles have been on, so have thought about this a bit more and have done a bit of a comparison test. So the way to get the cheap modern mantles to work on a caravan lamp is to use an old ceramic ring from a broken mantle and tie the new mantle to that, it fits the lamp just the same way the original did. When its lit it skrinks back and looks just the same as the original. This then works just like the original mantle and I hope settles jvh100's saftey points. Although i think you'd have to have quite a few lights going and seal the caravan to do yourself any damage . _________________ I can resist anything except temptation ! ( Oscar Wilde)
Suicide Jockey
Posted: Tue Sep 28, 2010 7:24 am Post subject: Re: gas Mantles |
jvh100 wrote: | Dalek63 wrote: | If you dont wish to pay what I think is excessive prices for mantles I have used very successfully in our Carlight and other caravans the mantles used on modern gas camping lamps. Just tie the string above the lugs on the gas light and make sure the mantle is central then light it. When it is lit the mantle goes hard and hey presto, you have a useable mantle for just a few pence.
cheers
George |
John. |
Oh Dear!!!!! |
Posted: Sat Oct 02, 2010 2:26 am Post subject: |
Dalek63
I had some difficulty sending you a PM earlier in the week. Did it arrive? _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
Scarlet Snail
Posted: Fri Oct 08, 2010 12:30 pm Post subject: Dangerous gas light |
He forgot to mention that some mantles are made of radio-active material. Jesus, Dalek, you could have killed us all! I'm going back to using my rusty old high-pressure petrol lamp.
Dalek63
Posted: Fri Oct 08, 2010 1:38 pm Post subject: |
hi
not had any message, try again my friend. _________________ I can resist anything except temptation ! ( Oscar Wilde)
