		| Author | Message |
		| Bayliss Thomas
				|  Posted: Fri Oct 01, 2010 11:30 am    Post subject: Which contact breaker points? |   |
				| I need to change the contact breaker points fitted to my 1928 Vauxhall 20/60 The distributor is DELCO REMY model 656 KA. This distributor uses an double set of points and I have looked high and low trying to establish which are the correct items to purchase, my request net is also cast far and wide. Can anyone here assist please?
		| Back to top |  |
		| michael1703
		| Back to top |  |
		| Bayliss Thomas
				|  Posted: Fri Oct 01, 2010 6:58 pm    Post subject: |   |
				| They do look very similar but I am not sure if they are the ones I need. I have emailed Holden asking. Thank you for the lead  |  |
		| Back to top |  |
		| michael1703
				|  Posted: Fri Oct 01, 2010 7:06 pm    Post subject: |   |
				| If they arent the ones and they cant point you to the right ones, I'm pretty sure you can get Lumenition for your car
 I know some people prefer points but if you cant get them then at least you have something
		| Back to top |  |
		| traction39
				|  Posted: Fri Oct 01, 2010 7:19 pm    Post subject: |   |
				| Here is a potential supplier State-side. Small piece, low postage costs. Check the stock list:
 www.collectorsautosupply.com/DELCO.PDF
 There is an email address at the bottom!
 Alistair
		| Back to top |  |
		| Nic Jarman
		| Back to top |  |
		| Bayliss Thomas
				|  Posted: Sat Oct 02, 2010 11:48 am    Post subject: |   |
				| Many thanks for all the leads, I will try A.Archer as first port of call, noted that they deal with vintage Vauxhalls, excellent.  |  |
		| Back to top |  |
