Old Engines
PostPosted: Fri Feb 11, 2011 9:37 pm    Post subject: Old Engines Reply with quote
Years of fascinating reading here, including how to make your own piston rings!
http://www.oldengine.org/
PostPosted: Thu Feb 17, 2011 5:28 pm    Post subject: Re: Old Engines Reply with quote
I remember, Peter, when I was very young at the latter end of the war, watching my Dad turning piston rings from a grey cast-iron pipe off the scrap heap. Using an ancient line-driven lathe.
The car gave years of service after that on private hire until sold.
I've never tried to replicate it and doubt whether I could. And certainly not with the equipment he had available.
Jim.
PostPosted: Thu Feb 17, 2011 6:35 pm    Post subject: Reply with quote
Proper engineering Jim! Great stuff. Do you still have his lathe?
PostPosted: Fri Feb 18, 2011 6:51 pm    Post subject: Reply with quote
No Peter, but it may give you some idea of the age when I tell you that the lathe was gratefully collected by Sheffield Industrial Museum when the premises were demolished in 1982. They also took a pillar drill with a 4ft (approx) side flywheel with a handle on the priphery to wind it and a similar horizontal flywheel on the top. That may be where my early teenage muscles came from!
Jim
PostPosted: Wed Feb 23, 2011 2:34 pm    Post subject: Reply with quote
Hi Jim,
Not quite in the same league, but I have a little bench drill that belonged to my father. It has a crank handle on the side and a flywheel on the top and feeds automatically. Quite clever.
I guess your's was a much bigger version of the one in this photo:
P.
PostPosted: Wed Feb 23, 2011 5:16 pm    Post subject: Reply with quote
Rather bigger Peter. Floorstanding, about 7ft high and would take drill bits over 1 inch diameter. The cast flywheel and winding wheel were rather beautiful, having "S" shaped spokes which suggested action.
We did also have a small bench pillar drill driven by the line-shaft, but we did not use that much.
The lathe was also driven by the line-shaft (along with grind-stones and buffing wheels etc.), but I think it may have originated as a treadle machine.
Jim.
PS useful looking workshop you have there, with many signs of home adaptation.
PostPosted: Wed Feb 23, 2011 5:42 pm    Post subject: Reply with quote
To see it in the flesh visit Brooklands Museum. Wink
I'm afraid mine is a pale imitation..
http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=4638&postdays=0&postorder=asc&start=30
PostPosted: Thu Feb 24, 2011 12:23 pm    Post subject: Reply with quote
Must have seen it and forgotten. Visited Brooklands on the way back from the Romahome IOW Rally late last year.
Oh, the advantages of old age! Embarassed
