Gerrit
Joined: 20 Jan 2010 Posts: 15 Location: Stramproy / Netherlands
Posted: Wed Jan 20, 2010 8:42 pm Post subject: Dutch Ford 104E introducing |
Hello,
My Name is Gerrit age 56.
I am from Holland and working on Ford 104E
My other project is a FT-Bonito build in 1975
But this forum is for the realy old cars.
My Ford 104E is from 1954
The previous owner of this car had it in the barn for 40 years or so.
It is looking good because the paint is done in about 1980
There are some parts missing
Amp and petrol instruments are missing
The steering gear has far to much play.
I am still looking for a new steering Nut for LEFT driven car.
Have been searching for 4 month or so but nothing found on internet.
Does some one know where to get a steering gear or parts for 104E ?
The English set is just the other way so I need LEFT from 104E
I will try to give some updates on this project in future.
owner of:
1970/1975 chassis/rebuild FT Bonito kitcar
1954 Ford 104E
http://www.ftbonito.info
CMI-Cars
Posted: Wed Jan 20, 2010 8:50 pm Post subject: |
Hello Gerrit
Nice cars, specially the Ford
Im not sure on what a steering nut is (english isnt so good in tehnical terms)
if you can send me a picture on email I can put a add in the veteranclub here in Denmark. I have found both the cars and parts to in on there. _________________ 1938 Ford 10 7W
1948 Ford Anglia E04A
1949 Ford Prefect E493A
1950 Ford Prefect E493A
1952 Ford Anglia E493A
1953 Volvo PV 831
3x1953 Ford Anglia E493A
3x1954 Ford Popular 104E
1955 Ford Popular 104E
1956 Ford Popular 104E
www.cmi-cars.com |
Gerrit
Posted: Wed Feb 03, 2010 9:53 pm Post subject: Found someone who can make the parts for steering gear |
Found someone who can make the parts for steering gear.
Its cold in the Netherlands and I am not working on the car these days.
last week I found a company wich can make my steering gear parts.
It will cost a lot...
But it will never get play after this repair.
Parts can be made much better as in the old days.
I will keep you informed.
Thanks for the reactions
owner of:
1954 Ford 104E
Beetlefan
Posted: Wed Feb 03, 2010 11:15 pm Post subject: |
Hi Gerrit, I've never seen an FT-Bonito before either,I'm sure the Moderators wouldn't mind you posting more information about this very rare car?
The Ford looks great too and it seems in very good condition,good luck with the search for parts for it! |
Gerrit
Posted: Mon Feb 08, 2010 9:03 pm Post subject: There is a Beetle as bottom |
An FT Bonito is a kitcar that late 60s, early 70s was on the market. The letters stand for FT Fiberfab Transformation, a German company that's made this polyester body. The polyester body is mounted on the chassis of a VW Beetle. Together with some other parts of cars could then be build a relatively low-budget sportscar .
In the Netherlands there are about 100 of these cars which currently have approximately 20 have an MOT approval.
In Great Brittain I know there are also some Bonito's some times with another chassis.
Nice on this car is that every thing you make your selves is ORIGINAL.
Special on the Ford is that all must be made just as original.
owner of:
1954 Ford 104E
http://www.ftbonito.info |
Gerrit
Posted: Wed Mar 02, 2011 11:02 pm Post subject: Some update for the Popular. |
Now we are discussing here the Bonito and thats off topic.
I start with update the popular 104E.
Got the steering box repaired.
It had 7 cm play on steering wheel.
Metal company Basco from Waalre Netherlands reproduced the worm and nut inside parts from the steering box.
They are just the like mirror to the 103E parts.
There was much play.
Now parts are new hardened and chemical nikkel process on surface.
Just some teflon on the parts and no grease is nesesary.
If someone needs these parts its not cheap but drawings are ready so you can order steering box parts in Waalre Netherlands.
I am looking for the metal part for the door window mechanism.
The part under the window glass is totally rusted away.
Perhaps someone has these parts in UK ?
Replaced the axe from carburetor valve.
Car is much better driving 90KM/h !
Foto's come next time.. _________________ owner of:
1954 Ford 104E
BMW bike K1
Posted: Thu Mar 03, 2011 9:45 am Post subject: Re: Some update for the Popular. |
Good work Gerrit. Look forward to seeing the pictures
| Gerrit wrote: |
My Austin Cambridge's drivers window has gone like this, it's from years of the car being parked outside with water running down the window and rusting the channel at the bottom. To the extent that the window drops out and hits the bottom of the door if you wind it down more than half way! My solution is to find a better secondhand door, as the skin isn't that wonderful either.
Try this place: http://www.thepopshop.org.uk/Pages/Interior%20page.htm
I think what you need is C: Door Window Channel. |
P3steve
Posted: Thu Mar 03, 2011 10:05 am Post subject: |
Yep my Standard Ten is the same as well, goodness knows where I'll find replacements. Nice Ford keep us posted on how you get on. Regards Steve _________________ If the world didn't suck we'd all fall off |
Gerrit
Posted: Mon Apr 04, 2011 9:40 pm Post subject: Update on the old Ford |
Here are some pictures
There are some big problems to overcome.
Steering gear worn out 7 cm play on wheel
Pedal axis holder broken.
And such parts are important if you have compete mechanical brakes
Pedal holder
Steering gear
Broken
Other side
Easy to get parts out, just get the floor out
It was not that easy...
for this part i had to remove exhaust,front axe subframe,brake and clutch mechanism.
The pink paint is Hammerite i painted when i replaced the radiator _________________ owner of:
1954 Ford 104E
BMW bike K1
Churchill Johnson
Posted: Mon Apr 04, 2011 11:22 pm Post subject: |
Love the speedo 140mph cor!!!!!! bit like the 90mph ones fitted to the Y models  |
Posted: Mon Apr 04, 2011 11:28 pm Post subject: |
| Churchill Johnson wrote: | Love the speedo 140mph cor!!!!!! bit like the 90mph ones fitted to the Y models  |
140 kph
86 mph is still pretty optimistic  |
Gerrit
Posted: Tue Apr 05, 2011 9:40 pm Post subject: The dash instruments,Electro system and steering gear |
A rain weekend and research on internet for a half year result in better electrical system in the 104E.
On the dash where missing 2 instruments, the amps and petrol meter.
I found them but it was not sure they would work.
Amps meter was ok but petrol did not work.
I dismounted the petrol meter and found that the wire between 2 coils was green and broken.
Once repaired the meter was ok.
The dynamo can be adjusted by changing the position of the third brush.
So it is now making about 10 amps.
All direction lights were replaced by LEDS exept on the back site
On the front wings I placed new round direction lights.
Its not original but traffic was looking at left turns and did not see where i was going.
Also all locks and roof are replaced this winter.
Here pictures from dash and more.
Het stuurhuis
The parts for the steering gear are made by Basco from Waalre.
Thats a company which makes parts for ASML and Philips.
The NUT and worm are complete remake now without play.
Here some foto's :
Steering gear new parts greased with teflon.
Its surface is nickel and it will never get play again since processes are much better than in the old days.
1954 Ford 104E
BMW bike K1
pryantcc
Posted: Thu Apr 07, 2011 12:24 pm Post subject: |
I love the photos of the steering parts, fantastic machining! Do you have pics of the old worn ones?
Great work by thes way! |
Churchill Johnson
Posted: Thu Apr 07, 2011 9:31 pm Post subject: |
| Richard H wrote: | | Churchill Johnson wrote: | Love the speedo 140mph cor!!!!!! bit like the 90mph ones fitted to the Y models  |
140 kph
86 mph is still pretty optimistic  | RH you don't know me yet bit tonque in cheek [KPH], but have you ever seen the 100MPH Bellamy Ford Pop |
