Bedford 1950 K Truck
50sDreamer
PostPosted: Wed May 11, 2011 1:59 pm    Post subject: Bedford 1950 K Truck Reply with quote
Hi - I'm a new user and recent buyer of a Bedford 1950 K Truck. I am based in Brisbane Australia and from reading posts my vehicle must have been a frame only import to Australia.
My first question is did the frame include the engine - mine has a stromberg carby? My son kindly transpoted the vehicle home for me on his small low loader semitrailer!! Laughing
A few pics are at http://photobucket.com/BedfordK
PostPosted: Wed May 11, 2011 2:55 pm    Post subject: Reply with quote
Welcome to the forum!
If it's anything like my Holden-bodied Bedford ute, then yes it would have been shipped with an engine from the factory.
victor 101
PostPosted: Wed May 11, 2011 5:34 pm    Post subject: Reply with quote
when I was young you would see the chassis being driven to the docks or bodyshop, a brave sole perched on a seat clinging to a steering wheel, his only luxury was a windscreen if fitted.
50sDreamer
PostPosted: Thu May 12, 2011 9:55 am    Post subject: 1950 Bedford K Reply with quote
Thanks Rick - I think you are right - a 214 cu inch motor, 6 cylinder - but who would have been the engine maker??
My first issue is a reasonable fast water loss from somewhere at the back of the engine. I have been told this will probably be a corroded out core plug or in England possibly called a freeze plug - in the engine head.
Can I buy such a part in the UK? Are they still available or will I need to have one machined up (and how can I get the specs for the plug - anyone got an engine manual for sale??) Question
PostPosted: Thu May 12, 2011 10:49 am    Post subject: Reply with quote
They are called a 'Welch Plug' in some quarters. Usually you will find you need one of a standard set of sizes to fit. If one has started to leak, the rest might be soon to follow, so I suggest replace them all.
Measure the plug when you can get at it and visit your nearest Repco outlet, they should be a common stock item.
Churchill Johnson
PostPosted: Thu May 12, 2011 9:32 pm    Post subject: Reply with quote
As has been suggested replace all these plugs later types were plated to help stop rust i would check the state of the coolant if it has been topped up with water to often it will be rusty so use a good flushing agent then remove the core plugs and let it dry out and blow out the head and block with an airline you ask about the engines these were made by Bedford they originated as a Chevrolet engine and over the years improved on i spent a couple of years working on these and the TK and O and S models for a main dealer back in 1965-66 and at times drove an OXO model breakdown lorry for the same dealer.
emmerson
PostPosted: Sun May 15, 2011 9:09 pm    Post subject: Reply with quote
Slightly off topic, but when I was about 17/18 in the fifties I was sent by train to pick up a new vehicle from the Austin main dealer. This turned out to be a bare chassis, to be built up into a mobile shop. There was no protection at all, and the seat was made out of plywood, with no cushion.
I had on only my jacket, as I had expected to be driving a new car back, and it was the end of January. When I got back, after a fifty mile journey, it was dark, wet and horrible, and I was so cold that I had to be lifted off the seat, and it was a couple of hours later before I could move my fingers! In compensation, I was told not to come in until dinner time next day!
And all for 1s 6d an hour!
50sDreamer
PostPosted: Mon May 16, 2011 1:00 pm    Post subject: 1950 Bedford K Reply with quote
Emmerson - you try telling that to the young fellers today and they dooon't believe you!!
50sDreamer
PostPosted: Mon May 16, 2011 1:04 pm    Post subject: Bedfork 1950 K Truck Reply with quote
So gents - parts for my restoration job of the 1950 Bedford K.
I now know that it was a chassis only export from UK to Australia, but some folk say that the radiator panels and mud guards were shipped also. Mine are OK but I am missing the Bedford badge that would have been on the radiator panel. Anyone know where I can buy one or are they rocking horse poo??
50sDreamer
PostPosted: Mon May 16, 2011 1:08 pm    Post subject: 1950 Bedford K Reply with quote
I also need a manual for this truck that details the engine and drive train - a workshop manual I guess. Any suggestions or offers please?
Churchill Johnson
PostPosted: Mon May 16, 2011 10:21 pm    Post subject: Re: 1950 Bedford K Reply with quote
will have a look how many gears?
llllmikellll
PostPosted: Fri Jun 10, 2011 1:22 pm    Post subject: Reply with quote
Ooo, nice little truck you got there.
I had one (unrestored) some years ago but sold it to concentrate on my Morris J.
There were some fully brit built versions in Aust. You can tell them immediately by the panel under the door. The GMH ones have a scolloped shape, the brit ones are just flat. Sometimes wish I still had it, but cost of running etc.
When you do the welch plugs, use brass ones.
cheers and good J
Mike in Melbourne.
Mog
PostPosted: Tue Jun 14, 2011 9:17 am    Post subject: Reply with quote
I can remember truck chassis , been driven around in the Uk. The driver more or less sat on a box with a bit of plastic in front of his face ! This was in the 1960's.
