The most commonly used part.
PostPosted: Fri May 20, 2011 11:23 pm    Post subject: The most commonly used part. Reply with quote
Other than a battery the 7 inch headlamp must be close. The rear lights and indicators on the Minor were widely used as well. Was the tail light cluster on the mk1 Cortina not used on one of the Bedfords.?
The Clan Chieftain
PostPosted: Sat May 21, 2011 8:54 am    Post subject: Reply with quote
Since you normally get 5 of them per car and they haven't changed much over the centuries I think I'd put forward the Schrader valve for the award.
Riley Blue
PostPosted: Sat May 21, 2011 10:37 am    Post subject: Reply with quote
The fuse must figure strongly, wouldn't you say?
PostPosted: Sat May 21, 2011 10:42 am    Post subject: Reply with quote
Nut behind the steering wheel? Very Happy
Seriously though I bet is going to be electrical , as Lucas stuff was on so many vehicles in the UK from the 30's to the 80's. Control box must be up there.
Scotty
PostPosted: Sat May 21, 2011 1:45 pm    Post subject: Re: The most commonly used part. Reply with quote
I remember them being used on the TVR Vixen S1's -
My vote for most commonly used part would be - Piston, in all the various makes of engines a single size and type would be fitted into.
PostPosted: Sat May 21, 2011 7:20 pm    Post subject: Reply with quote
What about the split-pin?
PostPosted: Sat May 21, 2011 10:07 pm    Post subject: Reply with quote
Nuts
2002 MINI Cooper 'S'
michael1703
PostPosted: Sat May 21, 2011 10:22 pm    Post subject: Reply with quote
jiggle pin
PostPosted: Sat May 21, 2011 10:50 pm    Post subject: Reply with quote
MVPeters wrote:
Nuts
Hey !! it was a perfectly good question.... Exclamation
Laughing Laughing Laughing
Minxy
PostPosted: Sun May 22, 2011 2:26 pm    Post subject: Reply with quote
These!
PostPosted: Sun May 22, 2011 7:53 pm    Post subject: Reply with quote
Many early cars were mostly constructed of wood.
Screws.
PostPosted: Sun May 22, 2011 8:28 pm    Post subject: Reply with quote
20/50 ?
PostPosted: Mon May 23, 2011 7:06 am    Post subject: Reply with quote
Sparking Plugs?
PostPosted: Mon May 23, 2011 2:55 pm    Post subject: Reply with quote
My nomination for the single most commonly used item, replaced most often, fits almost any vehicle from the 20's until quite recently, made by hundreds of manufacturers all over the world & probably highest volume item sold is:
the 5 Watt bulb
PostPosted: Mon May 23, 2011 6:07 pm    Post subject: Reply with quote
the 5 Watt bulb
I'd go along wth that Mike with the proviso that you include 6W bulbs. Throughout most of my life side lamp bulbs etc were always 6W. Only in more recent years have they "lost" a Watt. What!
For Michael1703 - Jiggle pins are not very common! I have never come across a vehicle with more than two and lots have none at all.
I am serious - now you had better go and find one!
Jim.
