gillberry
Posted: Thu Jun 16, 2011 8:09 pm Post subject: Spare Wheel |
Hi all having just had a blow out and discovered that the spare was the wrong pcd we are now after a spare of the correct size . We are after a 4 stud 13" with a 4 1/2" pcd and a 2 3/4" centre hole . Originally these wheels had 3 studs on for the hub cap to be applied and to the best of our knowledge were made for b&b trailers .Any help or advice would be much appreciated . |
Posted: Thu Jun 16, 2011 8:16 pm Post subject: |
Hi, is this for the Amazon or the caravan? |
gillberry
Posted: Thu Jun 16, 2011 8:24 pm Post subject: |
sorry this is for the caravan a 1967 cheltenham nyala, it came with a spare four studs wheel so when we got it we changed the tyre etc always made sure that it was inflated etc, but never thought to check it was the right PCD untill we had a blow out on the A11 the police had to close a lane for us then we found out the PCD was wrong and the caravan ended coming home on a low loader  |
Mog
Posted: Fri Jun 17, 2011 7:55 am Post subject: |
I also had a problem, I bought a second hand Ford, from a dealer. After about 2 years and 400 kms from home, I found that the spare wheel did not fit. What I worked out was that the dealer to please another buyer had taken the spare out of my car and changed them over. The other guy would have had the same problem..... |
Posted: Fri Jun 17, 2011 9:38 am Post subject: |
Gillberry.
I don't know anything about PCD, but I have several old Austin A30/A35 wheels sitting here, they're 4 stud and 13". If you find out this is the correct PCD/centre hole then you're welcome to one. I might even be able to bring it to Norfolk next time I'm up that way.
Richard. |
gillberry
Posted: Fri Jun 17, 2011 10:32 am Post subject: |
Richard H wrote: | Gillberry.
Richard. |
Many thanks for the offer , we are still trying to get hold of more knowledgeable cheltenham owners to find out what car based (if any) wheels will fit but as the axle stubs are B&B we have a feeling with the knowledge gained so far that only these wheels will fit . If we find out otherwise and your wheels are a fit we will definitely pm you .
Simon and Jayne . |
gillberry
Posted: Fri Jun 17, 2011 2:24 pm Post subject: |
This is a pic of the wheel we are after .
Posted: Fri Jun 17, 2011 3:03 pm Post subject: |
PCD or Pitch Circle Diameter is the centre-centre distance between OPPOSITE holes on a 4-stud wheel. It may not be the same as the distance between ADJACENT holes. It's more difficut to measure on a 5-stud wheel.
I think A35 & Mini wheels have a 4" PCD.
You also need to consider OFFSET which is the difference between the rims & the wheel mounting flange - FWD cars usually have negative offset, RWD cars usually have zero - positive offset.
I would imagine that trailers usually have zero offset - the basic objective is to get the centre-line of the tyre over the centre-line of the bearings.
There are exceptions.
Don't use metric wheels on Imperial cars! (seriously).
There's another thread here:
http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?p=69830&sid=08599bea87b1877b0e6e3d29c8373296
Hope this helps. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
JohnDale
Posted: Sat Jun 18, 2011 4:47 pm Post subject: |
Hi Gill, I have just put a set of brake shoes on a friends MkV Alpine which has very similar wheels, even down to the hub cap mountings, which would make me think your wheels may be some type of Rootes wheels. Sorry I don't have the PCD or centre info & he's now away off shore so can't get that for a fortnight. Cheers,JD. _________________ 1958 Ford Zephyr Mk2 Convertible
1976 Ford Granada Ghia. |
alan 869
Joined: 07 Mar 2011 Posts: 388 Location: Linköping Sweden
Posted: Sat Jun 18, 2011 5:24 pm Post subject: |
The B&B axels were fitted to many makes of caravan. I think the rim is pretty standard. Any scrapped van from the same period that has B&B frame and axels should fit. Just a matter of finding a caravan breakers that would have second hand ones.
In the 50s they used car rims. My Vogue had Austin A40 Somerset wheels as standard.
I would be very suprised if a 13 inch Sprite, Willerby or Astral wheel didn´t fit.
Most caravan manufacturers bought the chassi and other under gear and made just the bodies themselves. The two biggest manufacturers were Peak and B&B. They only did chassis, axels and hitches, which they supplied to the caravan/trailer factories |
mollymidget
Posted: Sat Jun 18, 2011 8:59 pm Post subject: |
Leave this with me Gillberry, I will ask my Dad who used to work for B&B then ALKO who took over from B&B, you could also try calling ALKO they may have some history files, their based in Southam Warwickshire |
gillberry
Posted: Sat Jun 18, 2011 9:42 pm Post subject: |
mollymidget wrote: | Leave this with me Gillberry, I will ask my Dad who used to work for B&B then ALKO who took over from B&B, you could also try calling ALKO they may have some history files, their based in Southam Warwickshire |
Hi thanks for the info I have sent ALKO a email and will wait and see if they come back to us |
Joined: 16 Oct 2008 Posts: 1164 Location: Upper Swan, Western Australia
Posted: Sun Jun 19, 2011 11:40 am Post subject: |
Why don't you take one of your good wheels to a motor wreckers and just ask for a wheel the same?
Keith |
gillberry
Posted: Sun Jun 19, 2011 11:59 am Post subject: |
Keith D wrote: | Why don't you take one of your good wheels to a motor wreckers and just ask for a wheel the same?
Keith |
thanks for the suggestion but we are looking for something from the 50s to 60s and our local scrap people do not hold stock going back that far, we have been there and done that before when we are looking for parts for our classics  |
RotaryBri
Posted: Tue Jun 21, 2011 12:01 am Post subject: |
The wheel on your caravan was never used by a car manufacturer. It was specially made for caravans and light trailers by Dunlop.
I have been up in my loft and dug out my old B & B Trailers technical information from my time working there and the wheel that you need is a Dunlop LP891 with a 4.5J x 13 with 5.5'' PCD (139.7mm) measured from one hole across the centre of the wheel to the opposite hole. The centre bore is 3.75'' (95.25mm) and the inset is 1'' (25.4mm).
If you look carefully at your wheel the part number LP891 and rim profile is stamped into the rim on the horizontal part of the rim.
This wheel was used by B & B, Peak, Caravans International (Sprite, Fairholme) etc. and as Alan says was used on all British caravans from the mid 50s up to the late 70s so should be found at a caravan breaker.
After that time and when ALKO took over they changed to a Vauxhall/Opel wheel with 100mm PCD.
I have all the information on wheel bearings and oil seals if anyone is interested.
I am sure that you should be able to find one. _________________ Keep Torqueing,
RotaryBri
1976 NSU Ro80 |
