Morris 8 Oil Leak
1stpop
PostPosted: Sun Jul 10, 2011 9:31 am    Post subject: Morris 8 Oil Leak Reply with quote
Having recently changed the engine oil and topped up the gear box oil I seem to have a leak. I have cleaned all round and finally found that is is coming from a small hole just in front of the the drain plug on the gear box. I looked through the book and cant find any answers and it didnt leak before. Any suggestions (bet its going to be something expensive!!)
Its a lovely Morris 8 Series E 1946
PostPosted: Sun Jul 10, 2011 10:02 am    Post subject: Reply with quote
Can't think of any legitimate reason for another hole next to the drain plug.
So, could it be a hole which has developed due to oxidisation on the outside coupled with a porous casting.
Perhaps you could seal it by drilling and tapping it and inserting another screw plug of suitable size
PostPosted: Sun Jul 10, 2011 3:00 pm    Post subject: Reply with quote
Is the hole far enough in front of the drain plug to be into the bell housing?
If so the problem could be engine oil from the back main bearing or gearbox oil from the first motion (input) shaft bearing. Bell housings usually have such a hole.
1stpop
PostPosted: Sun Jul 10, 2011 8:36 pm    Post subject: Reply with quote
Ive added a picture to show where the oil is leaking from
Churchill Johnson
PostPosted: Sun Jul 10, 2011 9:15 pm    Post subject: Reply with quote
yes that is the bell housing, and as been stated it will be either the rear main engine leaking or the gearbox if it is the box and it do's not normally need topping up it will be the engine you may also be able to tell if it's the eng if the oil is a little black in the sump and its the same colour dripping out then again it must be the eng.
victor 101
PostPosted: Sun Jul 10, 2011 9:20 pm    Post subject: Reply with quote
Seeing as it's only happened since you topped up the oil in the gearbox, I think we can safely assume that its leaking from the first motion shaft, I have no experience of Morris 8 so don't know what type of seal is used or wether it is just a spiral on the shaft that stops the oil escaping when the engine is running.
regards Rod.
PostPosted: Sun Jul 10, 2011 10:18 pm    Post subject: Reply with quote
This 'Drain hole'
On many a car I have seen this hole fitted with a loose fitting split pin.
I presume this is to stop the hole from becoming blocked by sludge etc.
Being a loose fit it will move with the vibration / movement from the car / engine so keeping the hole free from gunge.
1stpop
PostPosted: Sun Jul 10, 2011 10:53 pm    Post subject: Reply with quote
there is a loose fitting split pin in the next section between this area and the engine
PostPosted: Mon Jul 11, 2011 8:40 am    Post subject: Reply with quote
That'll teach me to look properly
The split pin in the rear of the engine sump is what I meant.
I would think if it was engine oil the leaking it would show on the sump side.
If this leak is from just this hole then I would suspect the gearbox.
Not been asked,
was the gearbox drained before you filled it, if not how much did you need to top up, most gearboxes should not need regular top ups if any at all.
If it needed more than a splash I'd check the front GB seal.
Roger
PostPosted: Mon Jul 11, 2011 11:39 am    Post subject: Reply with quote
If the cross section shown is of your gearbox, then it is quite cear that the "oil seal" is merely a "flinger ring". which rotates with the shaft
and "flings" off the oil like a catherine wheel.
Since the oil level should be well below the bearing and ring there should be no leak when stationary, nor when moving because of the flinger ring.
Are you sure you have not got too much oil in the gearbox to above the level of the level bung - or possibly the dipstick mark if fitted?
If over filling is not the problem, I'm afraid the problem is most likely engine oil. But then again over-filling the engine could cause the problem (among others).
That bottom bolt in the front flange (below the front bearing) also looks as if it might cause an oil leak if it has come loose because the bolt hole is not "blind" and goes right through the casing.
Jim.
PostPosted: Mon Jul 11, 2011 11:48 am    Post subject: Reply with quote
Roger-hatchy wrote:
This 'Drain hole'
Usually referred to as a "jiggle pin". Honest!
Jim.
PostPosted: Mon Jul 11, 2011 3:41 pm    Post subject: Reply with quote
As Arkwright would say J,J,J Jiggle it about. Laughing
Thanks Jim, had forgotten that.
PostPosted: Mon Jul 11, 2011 10:21 pm    Post subject: Reply with quote
I have rebuilt 3 of the series E box's, there are no seals (apart from a felt on on the rear, that was missing on all the box's I rebuilt!)
Jim is correct the box relies on machined scrolls to throw the oil back in the box, if the box is over filled there is a hole to feed the excess oil out in to the bell housing and out of the jiggle pin Smile hole.
I suspect its just overfilled, but if its more serious the good news is that the box is very simple to work on, somewhere on this forum I posted some pics on my SE box rebuild, I also added modern seals to the front and rear to aid the scrolls.
PostPosted: Tue Jul 12, 2011 1:18 pm    Post subject: Reply with quote
Tend to agree with Dave. It is very easy to get neurotic about oil leaks on motors of this age. Many had only rudimentary seals anyway and in some cases total loss lubrication was employed. I suspect that the box is overfilled and it probably didn't leak before because it had almost no oil in it!
So long as you have used the correct grade of oil and not some modern synthetic or detergent laden stuff and it is not making serious puddles on the floor I would ignore it as it will probably go away!!
Paul
1stpop
PostPosted: Tue Jul 12, 2011 2:08 pm    Post subject: Reply with quote
I think your right and its overfilled although its difficult to tell even by reading the dipstick which just says 'full'. Once again thanks to you all for the excellent advice Very Happy
No doubt i'll be back for more Rolling Eyes Rolling Eyes
