soldering fine mesh
1935Hillman
PostPosted: Tue Sep 06, 2011 7:18 pm    Post subject: soldering fine mesh Reply with quote
Hi all,
I am trying to solder a fine stainless steel mesh into a steel frame for my sump filter but am having problems. The solder / flux is clearly not right and the soldering is not making a good join. Does anyone have any experience of doing something similar or have any ideas regarding types of flux and wire for this application?
Any ideas as usual please.
Many thanks
Tim
PostPosted: Wed Sep 07, 2011 12:24 pm    Post subject: Reply with quote
Hi Tim,
I don't think you can soft solder to stainless steel. How about brazing? http://www.aluminumrepair.com/hts528.asp
I haven't tried HTS528 but their HTS 2000 is excellent for aluminium.
steammart
PostPosted: Mon Sep 19, 2011 11:23 pm    Post subject: Reply with quote
Hi Tim
To solder two dissimilar metals (e.g. Mild steel & stainless steel) you will need to silver solder them together. I use silver solder from cupalloys with a low melting point. it will depend on how thin your mesh is, as to wether you can use silver solder.
Martin
1935Hillman
PostPosted: Thu Sep 22, 2011 4:04 pm    Post subject: Reply with quote
Hi Martin,
Thanks for that. I have ordered silver solder and the appropriate flux from cupalloys. I'll let you know how I get on.
Cheers,
Tim
