Chemical Immersion Cleaning
British heritage cars
PostPosted: Sat Oct 22, 2011 7:45 pm    Post subject: Chemical Immersion Cleaning Reply with quote
Hallo,
Has anyone got experience with Chemical Immersion Cleaning a car?
http://surfaceprocessing.co.uk/index.html
Kind regards,
Jonathan
PostPosted: Sat Oct 22, 2011 7:52 pm    Post subject: Reply with quote
If I remember correctly, ukdave2002 did this with his Morris 8...I think!
PostPosted: Sat Oct 22, 2011 8:43 pm    Post subject: Reply with quote
Thanks Wink Will contact him!
Kind regards,
Jonathan
PostPosted: Mon Oct 24, 2011 2:04 pm    Post subject: Reply with quote
Yep I have used them twice, once for the Morris 8, had it dipped and E-primed.
http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=5790
And secondly my MGA, I just had this stripped back to bare metal, would have had it E-primed but at the time they had lost the subcontractor that did this.
http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=6134&postdays=0&postorder=asc&start=0
PostPosted: Tue Oct 25, 2011 5:58 am    Post subject: Reply with quote
Hallo,
And are you happy whit the result?
Would you advice me do do the dipping instead of sandblasting?
Kind regards,
Jonathan
PostPosted: Tue Oct 25, 2011 9:20 am    Post subject: Reply with quote
Hi Jonathon
I was happy with the results both times I used them, I did see a couple of reports of the E-primer not adhearing properly, but all the stuff they primed for me was fine.
I went for the immersion process rather than blasting for a number of reasons;
1)Blasting is great for simple panels; but you can't blast inside box sections, and sometimes its difficult to get effective blasting on some complex shapes.
2) The immersion process gets rid of everything that is not solid steel (you may not want this, as for example joints made of lead will be dissolved, as will any aluminium parts)
3) The E-primer process (if they are doing it again) is the same process that modern car manufacturers use; it should get primer into every cavity and box section.
It’s not cheap and if you have the time, space and can deal with the mess you could strip a car body at home and get it 95% “as well” stripped as an immersion process at a fraction of the cost.
