Headlights
steammart
PostPosted: Tue Nov 29, 2011 4:16 am    Post subject: Headlights Reply with quote
Can anyone tell me what size/model or any other information about what headlights/ headlamps were fitted to morris 8 series ones?
Thanks
Martin
PostPosted: Thu Dec 08, 2011 8:09 pm    Post subject: Reply with quote
Hi Martin
There were a couple of types fitted; early ones had Lucas R35, 6.5" diameter lens, later ( I suspect series 11) had Lucas L131 headlamps. 2 types of lens were availble; diffusa and fluted, everyone seems to prefer the fluted lens; they do look better,I dont know if the lighting is any better!.
Both lamps and rims were painted black.
Originally there was a mechanical dipping system, Lucas did offer a upgrade (lens reflector and with prefocused dual filliment bulb). Many owners have fitted motor bike bulbs and reflectors, retaining the original lens's.
Below is my series 1 tourer, the lamp on the RHS (of the pic) has an original lens (5/8" flutes), the LHS has an aftermarket lens, and the rim is chrome, so the whole lamp may be non original .
Mog
PostPosted: Fri Dec 09, 2011 12:48 am    Post subject: Reply with quote
Looks like you will have to get busy to fix the rust.
PostPosted: Fri Dec 09, 2011 3:43 am    Post subject: Reply with quote
Rust?
That's "patina".
2002 MINI Cooper 'S'
welder
PostPosted: Mon Dec 12, 2011 11:19 pm    Post subject: Reply with quote
MVPeters wrote:
Rust?
That's "patina".
Thank goodness for that. It seems that I have a gentle case of "patina" on my 1937 Morris 8 4-door.
And here was I, thinking it was corrosion Confused
Ian
steammart
PostPosted: Tue Dec 13, 2011 4:15 am    Post subject: Reply with quote
Thanks for that dave, much appreciated. Now begins the long hunt to find some, but I would guess there getting a bit like rocking horse droppings now
Martin
PostPosted: Tue Dec 13, 2011 5:03 pm    Post subject: Reply with quote
welder wrote:
MVPeters wrote:
Rust?
That's "patina".
Ian
Its a real art making the patina look original Smile Wink
Martin, the lamps come up on eBay quite often, its the original glass that are not so common, or if you are really stuck go for something like this: http://www.ebay.co.uk/itm/230635826906?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 not original but if its the difference between getting a car on the road ......
