Dynamo internal wiring
Doz
PostPosted: Sun Jan 08, 2012 10:34 pm    Post subject: Dynamo internal wiring Reply with quote
I stripped down the dynamo from the Austin 10 today (a Lucas E418), ran the multimeter over it and generally cleaned it up. It was in remarkably good condition, however the insulation on the internal wires from the brushes to the terminals and field coils has got extremely brittle and broken up in many places (photo below). I'm assuming that it's perhaps something heatproof - could someone that knows about these things please tell me what I should use to replace it? I'm presuming that covering the existing wires with heatshrink would count as a botch?! Many thanks, Bruce
PostPosted: Sun Jan 08, 2012 11:16 pm    Post subject: Reply with quote
Hi Bruce
You could buy some insulation sleeve, nothing wrong with heatshrink, it probably better than what was fitted originally. Very Happy
Cheers Dave
Doz
PostPosted: Mon Jan 09, 2012 3:41 pm    Post subject: Reply with quote
Thanks Dave, heatshrink looks like the easiest option (plus I already have some) so I think that's what I'll do.
jp928
PostPosted: Thu Jun 23, 2016 10:44 am    Post subject: Reply with quote
I also have an E418 on a Rover9 (1926m chain driven). Mine only has one wire coming out of the rear cover - can you advise please how yours is connected ? The wiring diagram shows D going to a +ve terminal in the main wiring centre, a lead from -ve post to -ve on wiring centre, and a green wire (lighter gauge than the other 2)from a shunt to the wiring centre.
Does this make sense?
thanks
jp
PostPosted: Fri Jun 24, 2016 5:18 pm    Post subject: Reply with quote
Not sure HS is a good idea as dynamos get quite hot inside when charging at high load which may soften it?
Rover P2
Morris Mini Traveller Mk2
PostPosted: Fri Jun 24, 2016 6:28 pm    Post subject: Reply with quote
The 3M company manufacture a Glass Cloth Adhesive tape.
This is a US link, acts as a guide.
http://solutions.3m.com/wps/portal/3M/en_US/Adhesives/Tapes/Products/~/Glass-Cloth-Tape?N=5473999&rt=r3
I used it on a regular basis when I worked in the UK and later we sold quite a lot when we had the Elec Wholesale Co.
goneps
PostPosted: Fri Jun 24, 2016 11:01 pm    Post subject: Reply with quote
Traditionally a type of closely-woven cloth sleeving would be used on internal wiring, usually either blue or red. As often as not it's still used for carbon brush wires. Any decent auto-electrician should have some. Heat shrink and PVC sleeving may become hard and brittle in an environment that always hot.
Richard
jp928
PostPosted: Sun Jun 26, 2016 5:39 am    Post subject: Reply with quote
Any chance you could comment on the pic of my E418 re extra leads please? Wiring diagram shows 3 leads, but there is only one there - the red/black lead to the left. What wires does your have ?
Thanks
jp
