Belt or Chain.
PostPosted: Sun Jan 15, 2012 10:18 pm    Post subject: Belt or Chain. Reply with quote
Most older cars have timing chains although some moderns are going back to chain drive. The belt is OK providing you stick to the schedules for changing them but some are too complicated and time consuming therefore expensive.My son had a V6 Calibra and the engine had to come out. Luckily his pal done it but it wasnt too expensive. Years ago when you bought a car you took the head off it and done a decoke. Now unless you know when the belt was changed you change it for peace of mind and you do the idlers and sometimes the water pump. Belt or Chain? Chain wins it for me.
The Clan Chieftain
PostPosted: Mon Jan 16, 2012 9:32 am    Post subject: Reply with quote
I couldn't trust any engine that has its camshaft driven by a rubber band! Gears or chains for me!
PostPosted: Mon Jan 16, 2012 9:41 am    Post subject: Reply with quote
Chains are not the most reliable at times! Shocked
PostPosted: Mon Jan 16, 2012 9:44 am    Post subject: Reply with quote
Yeah rubber bands smacks of penny-pinching to me, give me a chain any day
PostPosted: Mon Jan 16, 2012 2:50 pm    Post subject: Reply with quote
Oh they can clatter Dave, but in decades of maintaining and running taxis and limousines I only remember one breaking. And that happened to me.
I pulled in one day complaining to the owner of the company (my dad) that it was "pinging".
Unimpressed or concerned he loaded a passenger in for Spinkhill about ten miles away and I set off. About half a mile later the timing chain broke and split the cover, though without further engine damage.
In later years with Cortinas we rarely had a belt which achieved its change mileage though the engine was never damaged. Our mechanics got fed up with replacing Cortina belts at the roadside.
Later still as engine clearances on valves etc. got less, severely damaged engines cropped up at least once a year until we significantly reduced the change intervals.
Any complaints to manufacturers about faulty belts only produced a comment that they must have been wrongly fitted!
Jim.
PostPosted: Mon Jan 16, 2012 3:29 pm    Post subject: Reply with quote
Agreed, the Devon's one snapped leaving Tatton Park a couple of years ago, but I still prefer them to elaccy bands.
RUSTON
PostPosted: Mon Jan 16, 2012 6:47 pm    Post subject: Reply with quote
I always preffered a chain, though if you look on the Practical Motorist forum there seems to be a lot of chain breakage and stretching on modern engines so maybe there isn't much to choose between them nowadays?
Pete.
Measure twice...cut once!
exbmc
PostPosted: Mon Jan 16, 2012 8:15 pm    Post subject: chain or belt Reply with quote
Like Jim, i have only ever had to deal with one broken chain. That was on a Morris 1100, in the 60's.
There are certainly some "moderns" with a reputation for chain problems, mostly i think where a single chain is used. The V6 Suzuki engines are known to have problems, usually these can be staved off by using full synthetic oil, this stops the tensioner wearing away. Some of the smaller engined Vauxhalls have problems too.
Belts are i think, are not much more unreliable than chains. What matters is correct tension, and use a OEM belt, along with good bearings in whatever pulleys etc you have.
As Clan Chieftain started this thread, he might like to know,if he doesn't already, that the facelifted Marina, called Ital, had a belt on the 1.7 engine. These could be changed in about 5 minutes! We used to remove and check them at 12000 miles, then refit if ok. At 24000 miles, they were replaced, and all it cost extra was the belt, as it was comfortably done in the standard service time.
PostPosted: Mon Jan 16, 2012 9:52 pm    Post subject: Reply with quote
The problems I have with chains, are that one does not expect them to break alot of the time, so when one does, it is not a good thing, not that a belt going is, etc if you know what I mean. I know of 2 or 3 that have gone amoungst friends.
PostPosted: Mon Jan 16, 2012 10:04 pm    Post subject: Reply with quote
RUSTON wrote:
... if you look on the Practical Motorist forum ...
what, there are other forums out there??? Shocked Wink
PostPosted: Mon Jan 16, 2012 11:18 pm    Post subject: Reply with quote
Very true exbmc the 1700 belt was a dawdle but it was an engine I never liked especially doing the valve clearances with special clamps and shims...nightmare stuff. Give me the old A series and B series any day. Some of the Itals were fitted with the O seies 2 litre engine but I never had one of them.
The Clan Chieftain
RUSTON
PostPosted: Tue Jan 17, 2012 12:00 am    Post subject: Reply with quote
Sorry, wont happen again! Embarassed
Pete.
PostPosted: Tue Jan 17, 2012 2:29 pm    Post subject: Reply with quote
My modern is a Mondeo TDCi with chain driven camshafts. Apparently the chains are ok but the plastic tensioners can cause problems and turning the engine backwards is a No No!
Curiously enough my last car was a Mk I Mondeo Diesel and not long after I bought it I had the belt replaced but not long after that I needed a new cylinder head. The belt was fine but the idler wheel that tensions the belt had broken-up. There after I always asked for both to be changed and I then had 12 years of trouble free running. (I don't work on moderns except to change the oil.)
PostPosted: Tue Jan 17, 2012 5:13 pm    Post subject: Reply with quote
In the last 5 or 6 years the replacement interval for belts has increased....
Peugeot (on the 407's anyway ) recommend timing belts are changed at 160,000 miles or 10 years! Shocked
Our firm runs a few hundred 407's, we run the cars to either 150,000 miles or 5 years miles whichever comes first, I spoke with our fleet manager who couldn't recall a cam belt failure.. Surprised .perhaps they are chains in disguise Smile
The recomended interval for Stag timing chains is 15,000 miles, its quite common for them to stretch and do loads of damage Crying or Very sad
PostPosted: Tue Jan 17, 2012 6:38 pm    Post subject: Reply with quote
& then we get into the discussion about the often-fatal damage done when these belts break.
OK, so you might crack a timing chain cover when a chain goes, but modern engine design has "progressed" to the point that valves hit pistons when a belt breaks on many cars.
Did this ever happen with chains on classic cars?
2002 MINI Cooper 'S'
