Ford with the roof-mounted clock?
PostPosted: Sun Jan 29, 2012 10:35 am    Post subject: Ford with the roof-mounted clock? Reply with quote
I've a clock in the garage, mounted in a pod, which I think is roof-mounted and from a Ford, probably 1950s. Does anyone know which models (if any) had this feature? I'm guessing at Mk2 Consul/Zephyr...?
thanks, R
exbmc
PostPosted: Sun Jan 29, 2012 2:45 pm    Post subject: clock Reply with quote
Rick, i had a 1958 high line Zodiac, and that had the clock pod in the roof. It was above the windscreen in the centre. Later, i had a low line Zephyr, about a 1960 ish, but if that had similar i can't recall.
PostPosted: Sun Jan 29, 2012 3:00 pm    Post subject: Reply with quote
Interesting, thanks, I'll see if I can find a photo of one online to compare it with. It's in a mid-grey surround if I remember right.
thanks, R
JohnDale
PostPosted: Sun Jan 29, 2012 5:39 pm    Post subject: Reply with quote
Hi Rick, as far as I remember the clock was standard on the Zodiac & an optional extra on the Zephyr. I think the one in mine has been retro fitted as I seem to remember they were in a gray pod & not black.
Bit blurred but I took it in a dark garage & my eyes are failing(along with everything else) Cheers,JD.
1976 Ford Granada Ghia.
PostPosted: Sun Jan 29, 2012 5:49 pm    Post subject: Reply with quote
Thanks JD, I'll dig mine out and see if it's the same or not
Salopian
PostPosted: Sun Jan 29, 2012 9:48 pm    Post subject: Reply with quote
I'm slipping tonight - seeing the thread title had visions of trying to read the time on an external roof mounted clock! Nurse quickly ------
Jonathan Butler
Carcruiser
PostPosted: Tue Jan 31, 2012 11:13 am    Post subject: Reply with quote
Glad it wasn't just me who was thinking that!
cheers
Iain McKenzie
www.fairmilerestorations.co.uk
Mog
PostPosted: Wed Feb 01, 2012 7:58 am    Post subject: Reply with quote
Worcetershire ??? Never heard of it ! I did live in Worcestershire and sang in Worcester Cathedral once. I could walk down the road,from home,and then I was in Staffordshire.
Mog
PostPosted: Wed Feb 01, 2012 8:07 am    Post subject: Reply with quote
See !! I could not copy Worcsetershire correctly ! Back to the red wine and the cricket is on to-night. The Aussies playing the Indians in a twenty over match. Good fun ! Expected 60,000 people at the ground. Go the Aussies !
Carcruiser
PostPosted: Wed Feb 01, 2012 11:58 am    Post subject: Reply with quote
Ok ok, I'll change it! Never could type proper....
I should have stayed in Yorkshire - easier to type Smile
cheers
Iain McKenzie
Mog
PostPosted: Thu Feb 02, 2012 10:11 am    Post subject: Reply with quote
No problems ! I was born in Hull in Sept. 1944.
john-saab
PostPosted: Thu Feb 16, 2012 10:58 pm    Post subject: Reply with quote
That clock is exactly the same as the one in our 1958 Zodiac!
Rust Junky & oil addict.
