Wheel studs
Nick.S.
PostPosted: Sat Jan 07, 2012 12:09 am    Post subject: Wheel studs Reply with quote
Hello, the rebuild of my Austin Devon is progressing slowly.
i am missing a set of wheel nuts, so as a result one stud out of the four on each wheel is rather rusted and pitted. i will purchase the nuts from earlparts, or manufacter my own. if i have to i can produce my own wheel studs as well, but befor i do that, would these ones work?
http://www.ebay.com/itm/Austin-A40-70-Triump-Wheel-Studs-Classic-4-Pcs-/310282835503?vxp=mtr&hash=item483e4c562f#ht_1626wt_1037
P.S. before anyone gets the shivers about me producing critical parts, i do have a bit of machining background, i have built 3 running steam engines, 2 stirling cycle engines, as well as a 2-cycle compression-ignition engine, i also have a small foundry capable of pouring about 2-ish pounds of brass and about 4 pounds of aluminum. ( if anyone needs "unobtainium" parts Smile )
thank you for any and all help!
Nick.S.
PostPosted: Mon Jan 30, 2012 8:18 pm    Post subject: Reply with quote
I purchased the wheel studs and they arrived the other day. They are exactly what i was looking for! Smile Working on taking out the old ones and poping in the new Very Happy . I also purchased a NOS head gasket from this ebay seller for $26 plus shipping, all said and done it was $53, or 33 pound.
British heritage cars
PostPosted: Mon Jan 30, 2012 9:26 pm    Post subject: Reply with quote
Any pictures of you're restoration work? Very Happy
Kind regards,
Jonathan
PostPosted: Mon Jan 30, 2012 9:43 pm    Post subject: Reply with quote
Good result there Nick, I could have used a set of new studs on the Somerset I once had.
