Where can I get a stud made ?
Car-Nut
PostPosted: Thu Feb 02, 2012 3:06 pm    Post subject: Where can I get a stud made ? Reply with quote
I need 5/16 mild steel stud 4.25" long I cant get it from SNGB, Manners or SC Parts went to a engineering firm locally who roll threads and they wanted big money for a one off.
Can anyone here do it happily pay material, time PP etc…
Car-Nut
'62 S1 Jaguar E-Type 3.8 FHC
'70 420G - 13th from last RHD
'70 420G - 17th from last RHD
PostPosted: Thu Feb 02, 2012 3:20 pm    Post subject: Reply with quote
http://www.johnlawsondist.co.uk/?page_id=8
In Darwen.
Have 5/16" BSF x 3ft studding.
Julian
PostPosted: Thu Feb 02, 2012 6:21 pm    Post subject: Re: Where can I get a stud made ? Reply with quote
I'm a little surprised that you want a 'mild steel' spec stud, it's not really a strutural grade material for fasteners. However, why don't you just run a die down a length of bar stock and cut to length? Or buy some threaded bar maybe
Julian.
baconsdozen
PostPosted: Fri Feb 03, 2012 2:10 pm    Post subject: Reply with quote
Even B and Q (our local branch is called Stand and Queue) sell studding.
Doz
PostPosted: Fri Feb 03, 2012 3:04 pm    Post subject: Reply with quote
Aye, it's all metric though. Presuming it's the same stuff as the one near us sells anyway!
Julian
PostPosted: Fri Feb 03, 2012 3:28 pm    Post subject: Reply with quote
But you could weld a bit of 5/16'' set-screw thread on each end. I feel pretty sure that if the original spec is for mild steel you could get away with it!
Julian.
Doz
PostPosted: Fri Feb 03, 2012 3:41 pm    Post subject: Reply with quote
I think your earlier idea of running a die down a bit of bar stock would be simpler. It's certainly what I'd do.
Julian
PostPosted: Fri Feb 03, 2012 3:54 pm    Post subject: Reply with quote
I know, I agree with you/me Smile
I did once weld threaded bits onto bar-stock, it was to make a DIY style puller for some boiler tubes that needed replacing and so needed to be longer than the tubes. I just 'glued' it all up with my trusty stick welder, not really caring about quality as a failure would be nothing more than a slight nuisance, and of course the thing lasted for all 31 tubes while I wound the nuts up so tight my arm was bending!
Julian.
JohnDale
PostPosted: Sun Feb 05, 2012 5:17 pm    Post subject: Re: Where can I get a stud made ? Reply with quote
What threads(s) are you looking for - what length of thread?
I have a 5" one with 5/16" UNC both ends which I could cut & thread to your sizes or I can supply a piece of 5/16" UNF theaded rod. This would be free,cheers,JD.
1976 Ford Granada Ghia.
