My new storage arrived today..
PostPosted: Thu Mar 01, 2012 7:53 pm    Post subject: My new storage arrived today.. Reply with quote
And I'm please with it...
I bought a couple of 40" containers.. they are now sitting on an area that was designed for caravan storage, but these days has all sorts on it, its worked out as a very economic way of storing stuff.
Access was a tad tight but we got there Very Happy
The firm I used both supplied and delivered the containers they were really helpful and accommodating, they will also buy the containers back if I need too. PM me if you want their details.
Julian
PostPosted: Thu Mar 01, 2012 8:02 pm    Post subject: Reply with quote
I think old shipping containers are a great idea for a workshop, many years ago I knew of a place that had one as a workshop within an aircraft hangar - nice and secure. The standard procedure was to wait for someone to be doing some job inside it them creep up and belt it on the outside with a sledge hammer!
Julian.
PostPosted: Thu Mar 01, 2012 9:01 pm    Post subject: Reply with quote
Very handy Smile
websnail
PostPosted: Thu Mar 01, 2012 10:05 pm    Post subject: Reply with quote
Prats like that, need a heavy hammer across the knees.
PostPosted: Thu Mar 01, 2012 11:53 pm    Post subject: Reply with quote
Julian.
That brings me in mind of part of an apprentice training that I did as a teenager. The lathes in the workshop had big aluminium sheets up the back of them that held collets and things and it was a rather common trick for someone to creep up behind and whack it with a mallet just as the unfortunate operating the lathe was making a delicate cut.
Peter.
Mog
PostPosted: Fri Mar 02, 2012 3:28 am    Post subject: Reply with quote
I notice that there is a box around the lock, makes it more difficult to cut the lock. That should be done by anybody using them for storage. I would also suggest setting up an alarm , using a battery, so that it makes a lot of noise. Your goodies could be worth a lot of money but only a few quid to the scrappy.
Julian
PostPosted: Fri Mar 02, 2012 8:25 am    Post subject: Reply with quote
Peter.
I like that, I can just imagine the effing and jeffing as the poor operator has to start over with a new bit of bar stock!
Julian.
PostPosted: Fri Mar 02, 2012 9:23 am    Post subject: Reply with quote
Or sneak up and lock them in, is more what my friends would do! hehe
Hey dave, that firm, do they do transport too? I notice they have a hiab?
If you need a hand moving stuff over or anything doing in the containers give me a shout, DR Maintenance may be able to Assist, Smile
PostPosted: Fri Mar 02, 2012 11:49 am    Post subject: Reply with quote
A word of warning storing items in a container.
Due to containers being constructed in metal they are prone to sweating with the variable weather we have here in the UK and need to be opened regularly to allow the air to flow through them. Items will rust and any leather products will quickly become covered in mildew.
ROVER
One of Britain's Fine Cars
PostPosted: Fri Mar 02, 2012 1:01 pm    Post subject: Reply with quote
Funnily enough I started typing something similar but got distracted and didn't finish it Rolling Eyes I did wonder about stuff sweating away, but so long as it's opened regularly I guess it'd be ok like you say.
Julian
PostPosted: Fri Mar 02, 2012 1:18 pm    Post subject: Reply with quote
Actually, reference the sweating, if the container is in good condition and the door seals are intact then you've got a closed environment within and sweating shouldn't be such an issue. Containers in good condition are pretty much air and water tight - you can verify this because if they fall off a container ship (due to, say, high seas) then they float on the surface indefinitely.
Julian.
JohnDale
PostPosted: Fri Mar 02, 2012 2:18 pm    Post subject: Reply with quote
When I was in business I had an 'end of life' side opening forty footer which allowed full side forklift access to the engine test beds we built in there, c/w exhaust on the roof, lights for late working, & running water for the dyno. They do require maintenance to keep them decent & rust free though. Cheers,JD.
1976 Ford Granada Ghia.
Julian
PostPosted: Fri Mar 02, 2012 3:02 pm    Post subject: Reply with quote
But still a good option compared to another cheap option which is an old curtainsider artic trailer with the axles taken off, I would think....
Julian.
PostPosted: Fri Mar 02, 2012 3:12 pm    Post subject: Reply with quote
Leave the axles on, then at least if you move house you can just hitch up and move on, Just a bit of a ramp to get in! hehe
I wonder if vents in the container would help, or would it make it worse, probably worse. How about insulation, or painting them white as to reflect most of the heat?
PostPosted: Fri Mar 02, 2012 6:25 pm    Post subject: Reply with quote
Good point... I shall have to monitor the condensation issue, they do get warm inside, yesterday the outside temp was about 14 degrees, in the container it felt more like 25!
Re the security I will rig something up, the area is pretty good, the site a locked compound on a working farm, there is loads of scrap metal lying around (someone is breaking 2 routmaster buses) for the p*keys to go at first.
Dave re the firm; yes they do haulage, they are a one truck outfit, the hiab on that truck can lift a 4.5 tonne container, but only by jack knifing it (see the second photo) and they have to load from the side(parallel) otherwise the crane would overload. They are based in Cannock so not a million miles from us.
I may have to call on DR Maintenace Very Happy
