Fat flange Mini engine, in need of attention.
JC T ONE
PostPosted: Sun Mar 04, 2012 9:18 pm    Post subject: Fat flange Mini engine, in need of attention. Reply with quote
Here are som photos, of the "Fat" one .
Its one of those engines with the BIG bore, and tappet covers, that can be removed, from the block.
It has too many studs&bolts to hold the head, no vacuum on the destributer.
And as the title indicates a "FAT" flange where you bolt it to the gearbox, which have driveshaft couplings,
that share first name with one part, of 2 famues American comedians .
Shame is was left in a garden for so many years Rolling Eyes (since 1978)
removed the head, it had 4 stuck valves, but I worked a little on it, so they would move again.
This is what I found, after the head was removed.
This is NOT what you want to see, when you remove your drain plug Crying or Very sad
Hardly any metal bits on the magnet, engine only done 3000 miles.
bob2
PostPosted: Mon Mar 05, 2012 10:05 am    Post subject: Reply with quote
That engine has had it me thinks, a bit too far gone even if its so rare nowadays!
Kelsham
PostPosted: Mon Mar 05, 2012 10:14 am    Post subject: Reply with quote
What is the crank condition? I would like to see further pictures after its all cleaned up.
Regards Kels.
PostPosted: Mon Mar 05, 2012 11:25 am    Post subject: Reply with quote
I must admit that I had the same thought after the initial description. 30 years in the garden!
I think the first thing I'd do is see if I could get any over-bore numbers off the piston crown & see if there's enough metal left to do it again. I think +40thou = 1340cc is the max possible.
2002 MINI Cooper 'S'
Kelsham
PostPosted: Mon Mar 05, 2012 5:11 pm    Post subject: Reply with quote
If it's rare, a re sleeve would be an option. It is amazing what can be saved.
Regards Kels.
JC T ONE
PostPosted: Mon Mar 05, 2012 5:21 pm    Post subject: Reply with quote
Hi all Smile
Thanks for the input/comments/advice.
The engine will be rebuilt, I paid money for it Rolling Eyes and I dont like to waste money Wink
worst case scenario, I will make it into a coffee table Wink
I will check the pistons later, and it its too scared in the bores, it will be resleeved.
Here is a picture of the drive shaft coupling/axle.
JC T ONE
PostPosted: Mon Mar 05, 2012 5:25 pm    Post subject: Reply with quote
Kelsham wrote:
If it's rare
Regards Kels
Hi Kelsham,
Well rare is sometimes hard to describe ? but its a genuine 1275 S, with all the correct bits.
Regards Jens Christian
PostPosted: Mon Mar 05, 2012 5:55 pm    Post subject: Reply with quote
I had my Morris 8 engine re-lined, it probably added a couple of hundred quid to the rebuild cost, a 100 or so for the liners and about the same for the additional machine shop costs. Small benefit was that standard sized pistons and rings tend to be cheaper and everyone wants oversize Very Happy
Cranks can be metal sprayed if there is not enough metal for a regrind.
JC T ONE
PostPosted: Mon Mar 05, 2012 6:27 pm    Post subject: Reply with quote
Hi Dave,
Yes that sounds like a good option, and if I do, I might as well have the new liners bored out,
to fit the pistons in the engine (if they are OK?) as they have done so few miles.
bob2
PostPosted: Tue Mar 06, 2012 11:25 am    Post subject: Reply with quote
Hi JC, I dont think its worthed to rebuild that engine, send it to me instead!!
Razz
It will surely cost you but will be worthed in the end!!
Now you must buy a car to put that engine in!! Very Happy
JC T ONE
PostPosted: Tue Mar 06, 2012 12:05 pm    Post subject: Reply with quote
Razz
Hi N,
yes I imagine you would like that Wink nah I think I will keep it Smile
I will buy a 1½ liter Coca Cola, and pour into the bores, to see what happens ?
Yes I know I need a car for it Rolling Eyes but that will probably never happen.
I have all the Gold brocade seats, 7.5" S disc brakes, correct LP 883 S rims, but no car Sad
welder
PostPosted: Wed Mar 07, 2012 12:42 am    Post subject: Reply with quote
Regards Kels.
Kels, I fully agree. I've been involved in engineering all of my working life and firmly believe that with enough determination almost any mechanical device can be made good. Eventually Rolling Eyes
An engine is only a bunch of castings containing some things that go round and round and others that go up and down.
Ian
