Nick.S.
Joined: 08 Nov 2011 Posts: 64 Location: Manitoba, Canada.
Posted: Tue Mar 06, 2012 8:13 pm Post subject: what year is it? |
Hello, as the re-build on my austin a40 devon progresses, i am getting more annoyed by not knowing what year it was made
i was hoping that some one would have a book or referance sheet that might be able to tell me the approximate year that it was built.
here are some details,
Chassis #57049
Engine #1G398405
Many thanks!
Nick. |
exbmc
Posted: Tue Mar 06, 2012 8:44 pm Post subject: Dating |
| One old way of telling age, is through the glass. Not totally reliable now, on a car that could have had windows changed. Anyway, look at the Triplex badge on some side windows, and it will say toughened underneath. If you know what decade a car comes from, say the 50's, and there is a tiny dot under the G of toughened, then that glass come s from 1954. You can tell 1 to 9 with the dot, and if there is no dot, it's 1950 or 40 or whatever. |
Posted: Tue Mar 06, 2012 11:13 pm Post subject: |
Can you remind us what it looks like again?
Very early cars had smaller headlamps, most Devons were floor change but late ones were on the column, like the Somerset. Some had gold dashboards, others a wood effect.
I no longer have any engine or chassis no. details for the '49 I had unfortunately, but I may still have some other paperwork somewhere from the Austin Counties club, I'll have a look in the morning.
If push comes to shove the BMIHT may be able to help.
Nick.S.
Posted: Wed Mar 07, 2012 12:01 am Post subject: |
Thanks i'll take a look at it. Mine is a floor change, with wood grain dashboard, it also has the side vent windows.
found the body number to if it helps, its #175418
Agian, Thanks
Nick. |
Nick.S.
Posted: Wed Mar 07, 2012 1:19 am Post subject: |
| i think the years of production for this model was '47 to '51. exbmc, there is a little dot under the T of toughened, does that mean its '51? Almost all the windows are the same. |
exbmc
Posted: Wed Mar 07, 2012 8:15 pm Post subject: year |
| That's right Nick, it's only an old trade way of telling when a car was built, but can be useful. You know it's not a '41, or a '61 so it must be '51. It only worked while Triplex glass was marked like that. |
Nick.S.
Posted: Wed Mar 07, 2012 11:25 pm Post subject: |
thats so cool a bit cheaper than BMIHT too, i looked at them when i first got the car, but i decided to wait to see if it would run before investing to much money in it. speaking of running, i got the motor and transmission stuck together and on the frame, i put oil in it today. by cranking it over by hand there is about 10 pounds oil pressure!  |
British heritage cars
Posted: Fri Mar 09, 2012 9:26 pm Post subject: |
| Nick.S. wrote: | thats so cool a bit cheaper than BMIHT too, i looked at them when i first got the car, but i decided to wait to see if it would run before investing to much money in it. speaking of running, i got the motor and transmission stuck together and on the frame, i put oil in it today. by cranking it over by hand there is about 10 pounds oil pressure!  |
That's good news!
pictures are always welcome!
So what's next on your "to do" list?
Kind regards,
Jonathan |
Nick.S.
Posted: Mon Mar 12, 2012 10:31 pm Post subject: |
i got it running this weekend, so next is to sort out the cooling system so i can run it for longer
for this i have to make a brass casting for the water pump, the little brass cup that drives the carbon seal. i will try to remember to take pics of the pour. should be able to do it this coming weekend
i also made a banjo fitting for the fuel pump intake side, so that i can fit plastic fuel line on it. i will post pics soon. |
alangregory2448
Posted: Fri Mar 16, 2012 4:10 am Post subject: Re: what year is it? |
| Nick.S. wrote: | Hello, as the re-build on my austin a40 devon progresses, i am getting more annoyed by not knowing what year it was made
Chassis #57049
Engine #1G398405
Many thanks!
Nick. |
I think you are short by one number on your chassis no. as my records all show that there were 6 numbers not 5 on the chassis numbers for A40 Devons. Assuming your first 3 numbers i.e. 570??? are correct my records of chassis numbers makes me speculate your A40 was built late 1949 or in the first half of 1950. I don't rely too much on engine numbers as many A40's have had engine swaps sometime during their life. However your engine number is shown by my records to have been also built around the same era as the chassis, even if it's not the original to your car (but it could be) |
Nick.S.
Posted: Mon Mar 19, 2012 5:04 pm Post subject: |
its possible that i missed one, the tag is a little beat up and corroded.
thank you for looking it up
i did the casting for the water pump yesterday, turned out really well. it was my first cored casting as well!
i am using water bonded greensand that i made.
the furnace runs off of propane with an reil burner, it produces about 80,000 BTU's and right at the burn head about 3,000 degrees F.
The molten brass is around 1,800 F. so its lots of radiant heat to work around.
pics as promised
this is the mold box rammed and vented
opened with the pattern
pattern plate removed
pouring gates cut in
furnace rumbling away
molten brass
mold poured and cooling
shake out
before and after
Posted: Mon Mar 19, 2012 8:24 pm Post subject: |
Waauw what fanastic work!!
Can I orde the part? :p
Kind regards,
Jonathan |
Nick.S.
Posted: Tue Mar 20, 2012 9:44 pm Post subject: |
Thanks! i suppose if you need some cast parts i can give it a go i've got all the patterns now and thats what takes time to make.
i had decided to cast this part because the closest i could find to it was a whole new pump on fleabay for about 200 dollars! yikes!  |
