Posted: Fri Mar 23, 2012 5:28 pm Post subject: |
| MVPeters wrote: | Can we ask why you need 6' of this hose? Would it be possible to use 5'11" of steel/brass/copper pipe & two small connecting pieces of hose?
Alternatively, try a railway restoration site (Severn Valley?), since rly. equipment often has a vacuum braking system. |
6ft in total, cut into shorter lengths is what I meant by 70ins overall length. The route isn't straight either, so wouldn't suit lengths of copper pipe, with short rubber sections at either end. I've sourced some h/d hose which is much more substantial than what had been fitted.
Posted: Fri Mar 23, 2012 9:04 pm Post subject: |
| MVPeters wrote: | | Can we ask why you need 6' of this hose? |
That's the sort of question the coppers ask, isn't it..?  |
