What Battery
PostPosted: Mon Apr 02, 2012 7:54 am    Post subject: What Battery Reply with quote
What battery do I buy to power my flashing beacon, obviously it needs to last as long as possibe, as it won't have any charging untill I get home, it will only have a beacon on it mind.
emmerson
PostPosted: Mon Apr 02, 2012 10:57 am    Post subject: Reply with quote
I'd go for what they call a 12x12. These are used on small mobillity scooters, and seem to go on for ever. I have a spare one for herself's stand-by scooter. It's nevere been used on the machine, but I use it to jump start my ride on mower, and in two years I've never yet charged it.
About £30 as I remember. Also used on golf buggies, I believe.
emmerson
PostPosted: Mon Apr 02, 2012 11:07 am    Post subject: Reply with quote
PostPosted: Mon Apr 02, 2012 1:27 pm    Post subject: Re: What Battery Reply with quote
I'd go for LED flashing strobes, as seen on recovery vehicles, will give you much more battery life than a rotation beacon lamp....can't you strap a generator on somewhere?
PostPosted: Mon Apr 02, 2012 2:20 pm    Post subject: Reply with quote
Can they not be solar powered / charged these days.
And yes LED would be less power consuming in another way, no power to a motor that turns the beacon.
PostPosted: Mon Apr 02, 2012 8:22 pm    Post subject: Reply with quote
I have been looking at strobes etc, not decided on what to do yet, so many to chose from.
I have seen lots of engines with a alternator under the flywheel, wich powers head lamps and a battery obviously, but I am not keen on it att the moment, for the ammount I plan to do... Would it matter an alternator going backwards?
PostPosted: Mon Apr 02, 2012 8:30 pm    Post subject: Reply with quote
No as output is same in either direction before rectification surely
Rover P2
Morris Mini Traveller Mk2
PostPosted: Mon Apr 02, 2012 10:03 pm    Post subject: Reply with quote
Dave.
The cooling fan would be the only problem. Sucking instead of blowing.
Art
PostPosted: Mon Apr 02, 2012 10:11 pm    Post subject: Reply with quote
oh, thats the alternator off the list of ideas then, asI need to be able to reverse up ocasionally... lol
PostPosted: Tue Apr 03, 2012 7:53 am    Post subject: Reply with quote
Buzzy
See if these would do the job:
4 modes - bright white, red. green & flashing red. 40 hours run-time (maybe) on 3 little AAA batteries - included.
A local store in the US was selling these for $3.50 a pair a few weeks ago. I bought a dozen for use at the trolley museum that I volunteer at. If there's any left I'll get some more - e-mail me off-list if you want a couple.
http://www.ebay.com/itm/Brinkmann-9-LED-Multi-color-Flashlight-/320879363125?pt=US_Flashlights&hash=item4ab5e68435
MVPeters @ comcast.net
2002 MINI Cooper 'S'
PostPosted: Tue Apr 03, 2012 10:14 am    Post subject: Reply with quote
47Jag wrote:
Dave.
Art
For the low power you need cooling won't be an issue, also if air is sucked through the alternator rather than blown it will still cool.
PostPosted: Tue Apr 03, 2012 10:26 am    Post subject: Reply with quote
47Jag wrote:
Dave.
Art
quote="buzzy bee"]oh, thats the alternator off the list of ideas then, asI need to be able to reverse up ocasionally... lol[/quote]
PostPosted: Tue Apr 03, 2012 3:34 pm    Post subject: Reply with quote
If you run the alternator backwards AC output will flow backwards and forwards - instead of forwards and backwards! Wink
Jim.
Julian
PostPosted: Tue Apr 03, 2012 4:25 pm    Post subject: Reply with quote
47Jag wrote:
Dave.
Art
'tis a centrifugal fan. So works the same what ever the direction of rotation.
Though to be fair the vanes are slanted a little so it won't be as effective. I made a cooling fan once for an alternator out of some heavy aluminium plate - all I had was a drill and some tin-snips.
Julian.
PostPosted: Tue Apr 03, 2012 4:32 pm    Post subject: Reply with quote
Turn the fan around on the shaft?
