jessejazza
![](images/avatars/10400619334a3413ae31438.jpg)
Posted: Mon Apr 02, 2012 11:27 pm Post subject: Card/paper pancake filter for HS2 -- MG? |
I believe at one stage MG or mini did a pancake filter which took a paper air filter similar to a K&N in looks.
I've looked on the MGOC and Moss websites but can't see anything. Anyone help?
I have an old 50s three wheeler that i want to put an air filter on but don't like K&N or the cheaper foam ones (i do wonder how good these are).
thanks |
exbmc
Posted: Tue Apr 03, 2012 8:21 pm Post subject: air filter |
There was a pancake filter about, i think they were fitted on early model Sprites and maybe Midgets. I recall a few Mini Coopers having them on. You had to order two different ones, as one had a stub for the crankcase breather pipe. Now i am sure they had no replaceable element, you could not dismantle them. They were taken off right at the start of a service, and thrown in the soak tank. The one with the breather would be quite messy. Frankly, as i recall, they just made the vehicle "sound" faster, and also were prone to carb ice forming, as no heat was available. I don't recall who manufactured them, but Vokes made the larger versions found on the Riley Riviera. That was a sort of limited edition of the 4/68 with an MGA spec engine i think. |
Riley Blue
Posted: Tue Apr 03, 2012 8:38 pm Post subject: |
These are Vokes filters:
They come up for sale on Ebay occasionally but they're not cheap at £40-ish each. |
bob2
Posted: Wed Apr 04, 2012 7:41 am Post subject: |
I remember that you could buy similar ones new off the shelf, I did so in the 90's, and fitted one to my mini and you could open it up and replace the element, though I do not remember what was the element made of!!!
Do not know whether I threw it away or if its still somewhere in the garage, it was a chrome one exactly like those in the previous post photo.
Will have a rummage through this weekend. |
jessejazza
Posted: Thu Apr 12, 2012 10:19 pm Post subject: |
bob2 wrote: | I remember that you could buy similar ones new off the shelf, I did so in the 90's, and fitted one to my mini and you could open it up and replace the element, though I do not remember what was the element made of!!!
Thanks for your replies folks. I would be grateful if you can spare the time. |
bob2
Posted: Fri Apr 13, 2012 9:52 am Post subject: |
Hi jessejazza, did not go last wkend, but will go down there this wkend, cause it could be in a lockup near my mum's house, not that it will be any good to you if I find it since I am in Malta.
Not to mention this lockup is quite damp so it might have disintegrated by now as from what I recall it was very thin!! ![Very Happy](images/smiles/icon_biggrin.gif) |
bob2
Posted: Mon Apr 16, 2012 8:52 am Post subject: |
Looked for it but did not succeed, probably got thrown away in a clear out some time ago but I might have given it to someone else too since I do not usually throw away such things!! ![Confused](images/smiles/icon_confused.gif) |
jessejazza
Posted: Sun Apr 22, 2012 12:04 am Post subject: |
Thanks for your replies - success at last. The Herald 948 GFE1037 filter [twin carb HS2] - is a paper filter sandwiched between two circular plates as a complete unit £7 which is just what i was looking for. I think it was on early Midgets as well. |
