Rich5ltr
Posted: Sat Jun 02, 2012 10:51 pm Post subject: Anyone renovated an old Lucas solenoid? |
Quite a while since I've posted on here so hello chaps, I trust all's well?
The starter solenoid on my Aston is as far as I can tell the original but it's becoming a bit intermittent. Sometimes it doesn't start on the key but does when I push the rubber button. I've noticed the black Bakelite centre is now slightly loose in the ali' casing. So I'm thinking I might be able to disassemble it, clean it and reassemble and re-glue the centre in the case.
What I'm trying to avoid is replacing it with a modern equivalent. They are available for £20 but they look pants and made of cheap tin.
Anyone got any experience in doing this? Thanks...  |
JC T ONE
Posted: Mon Jun 04, 2012 3:29 am Post subject: |
Hi,
have a go at it, worst case, you need to buy a new, but then you atleast tried to save the old one.
It it dont pull, when you activate the button? then its probably the windings, or maybe just a bad connection. _________________ http://www.eurods.eu/wp/index.html |
Rich5ltr
Posted: Mon Jun 04, 2012 10:33 am Post subject: |
The button is manual so I think all it does is make the contact inside. Anyway after a little wiggle it works on the key again so it must be a lose connection inside. I just wondered if there are lots of gubbins inside which will fall out if I stirp it apart. I'll just have to have a go! Thanks... |
Joined: 23 Nov 2007 Posts: 4232 Location: South Cheshire
Posted: Mon Jun 04, 2012 10:48 am Post subject: |
The Lucas ST10 starter switch has a replaceable contact, the contacts do wear, why not buy a repro one and use the innards in the original?
Rich5ltr
Posted: Mon Jun 04, 2012 6:42 pm Post subject: |
ukdave2002 wrote: | The Lucas ST10 starter switch has a replaceable contact, the contacts do wear, why not buy a repro one and use the innards in the original?
Now there's an idea! Thanks... |
Posted: Tue Jun 05, 2012 1:58 am Post subject: |
Rich,
Just had a thought. Why not try and loosen the lock nut on the copper studs, push it in and turn it 1/2 a turn.this will present a new 'face' to the contact plate. I've never tried it but someone has to...... Go on, you know you want to.
Rich5ltr
Posted: Sat Sep 08, 2012 10:05 pm Post subject: |
In the event, on eBay I found an identical early 60s replacement for about £30, still in it's original Lucas box - perfect. |
