Morris 8 Series E Piston Rings
1stpop
PostPosted: Tue Jun 12, 2012 6:09 pm    Post subject: Morris 8 Series E Piston Rings Reply with quote
Having consulted my workshop book and started on replacing the piston rings I have hit a snag.... two pistons are marked wellworthy 502.136 +030 and the other two are marked 11580 30thous o/s. Can anybody give me any clue as to the correct piston ring size? none of the ones listed in my book are stamped on the pistons
1stpop
PostPosted: Tue Jun 12, 2012 8:22 pm    Post subject: Reply with quote
Just cleaned the bottom of the crank case and spotted the following:
A +2 +4 +3 +2
I presume this is the re-bore sizing? Can you get mixed piston ring sizes?
PostPosted: Tue Jun 12, 2012 8:28 pm    Post subject: Re: Morris 8 Series E Piston Rings Reply with quote
Ok all 4 pistons appear to be +30 thou, thru the period of the 8's life ,Morris did a great job of mixing metric and imperial measurements ! Mainly due to the acquisition of Hodgekis the French engine manufacturer.
The bores are 57mm as standard, but re-bores are in 10" incriments Shocked If you need them I'm pretty sure I have a set of +30" Wellworthy oil saving rings?.
1stpop
PostPosted: Wed Jun 13, 2012 4:10 pm    Post subject: Reply with quote
am I correct in thinking they have been re-bored? and thats what the +2 +4 and +3 mean?
Handyman
PostPosted: Wed Aug 01, 2012 11:11 am    Post subject: Reply with quote
No, these numbers have no reference to reboring. Whereabouts were they in the crankcases? Look more like running clearances for the mains or big-ends.
On your pistons, two are Wellworthy and two are Hepolite, but they are all plus 0.30", so the engine has probably been rebored two or three times.
I am not sure Wellworthy piston rings will fit into the Hepolite pistons, but I stand to be corrected or I'll check my piston service books and post again.
H
PostPosted: Thu Aug 02, 2012 11:33 am    Post subject: Reply with quote
The 11580 pistons have two rings of 2.22 mm width and two at 4 mm.
There appears to be 5 different Wellworthy pistons for the Series E.
There are ones with 3 rings which are two at 2.25 mm width and one at 3.00 mm.
There are also 4 ring pistons like the 11580 and they are stated as two at 2.25 mm and two at 4.00 mm.
There is also a few varieties of radial depth for the various Wellworthy pistons.
Rather than seeking rings for your existing pistons would you not be better looking for a set of four pistons with rings. At least you would have a better chance of obtaining reasonable balance.
