are the winscreen gaskets the same
Russ B
PostPosted: Mon Aug 14, 2006 4:01 pm    Post subject: are the winscreen gaskets the same Reply with quote
As used on the Anglia cars of the same period? Around the late forties and early fifties?
rustyreks
PostPosted: Sun Apr 29, 2007 11:08 am    Post subject: windscreen gaskets Reply with quote
Not sure have heard of guys putting together 2 prefect windscreens to make up a fordson windscreen they are quite alot bigger the fordson are steel the prefect are brass.By the way i thought your truck looks cool.Maybe contact small ford spares and check with them.http://www.smallfordspares.co.uk/ or scotts old auto rubber they would probably carry the original rubber for the fordson http://www.scottsoldautorubber.com.au/ hope that helps.rustyreks
