What have you bought for your car lately.
PostPosted: Thu Aug 23, 2012 11:02 am    Post subject: What have you bought for your car lately. Reply with quote
I had to "buy" (a word I dont like using) a diff pinion oil seal. A whole £7 from Earlpart. Laughing Skint again. Laughing
The Clan Chieftain
stuchamp
PostPosted: Thu Aug 23, 2012 2:48 pm    Post subject: Reply with quote
Pitman arm and both outer tie rod ends. Sad
Riley Blue
PostPosted: Thu Aug 23, 2012 3:30 pm    Post subject: Reply with quote
Petrol, lots of petrol Very Happy
PostPosted: Thu Aug 23, 2012 3:47 pm    Post subject: Reply with quote
Whats a Pitman arm.?
The Clan Chieftain
stuchamp
PostPosted: Thu Aug 23, 2012 8:11 pm    Post subject: Reply with quote
Splined arm or link that attaches to the steering box.
http://www.speedwaymotors.com/1955-1957-Chevy-Manual-Steering-Pitman-Arm,14628.html
D4B
PostPosted: Thu Aug 23, 2012 9:11 pm    Post subject: Reply with quote
2 x spare brake master cylinder repair kits
(found on ebay.fr)
Cool
norustplease
PostPosted: Thu Aug 23, 2012 9:45 pm    Post subject: Reply with quote
Electronic ignition.
1953 Citroen Traction
1964 Volvo PV544
1957 Austin A55 Mk 1
Boring Tucson SUV
Jason
PostPosted: Thu Aug 23, 2012 10:10 pm    Post subject: Reply with quote
4 x spark plug caps arrived and fitted today Wink
"people with money buy a Rolls Royce, people with taste buy an Alvis".
PostPosted: Sat Aug 25, 2012 7:25 pm    Post subject: Reply with quote
I found a NOS head gasket for the Dodge truck in Massachusetts, and it arrived safely here this week. Cheap to buy, but not to post....
New inner tubes and flaps were sourced for the Dodge tourer a couple of weeks back too, and are now in place.
PostPosted: Sat Aug 25, 2012 7:35 pm    Post subject: Reply with quote
Nothing...
ROVER
One of Britain's Fine Cars
PostPosted: Sat Aug 25, 2012 7:46 pm    Post subject: Reply with quote
Hi, I am always interested when folk fit electronic ignition (i am a fan Very Happy ) as to their reasons for doing it?
norustplease
PostPosted: Sat Aug 25, 2012 8:16 pm    Post subject: In Praise of Electronic Igntion. Reply with quote
Being a thirties car the Austin has a basic centrifugal advance distributor with points. It runs well enough in standard fettle, but cold starting, even using the priming lever on the pump, hammers the batteries whilst the car gets going and I wondered whether a simple electronic setup would improve the engine's response overall.
I'd had good reports from ATDC members of the Boyer Bransden setup, and although contactless is the ultimate way forwards, using this system which retains the points, seemed sensible in the context of a seventy year old car, with the added attraction of being able to revert back to the old system by the roadside with a spot of reconnecting if something fries the box of tricks.
Points last almost forever anyway with this system, and the condensor is redundant, so less to worry about in maintenance terms.
An improvement is immediately noticeable. Starting is easier and the car definitely idles and pulls much better. The installation is discreet and the box can be hidden out of sight behind the bulkhead.
Recommended.
1964 Volvo PV544
Boring Tucson SUV
Salopian
PostPosted: Sun Aug 26, 2012 12:51 pm    Post subject: Reply with quote
Slightly off topic - I have fitted several of these to my cars they are pretty good if you can use a soldering iron and best of all cheap! Original points retained should it fail as well and seem to last for ages. I've used them to convert mags to run as a coil set up as well.
http://www.maplin.co.uk/ignition-amplifier-kit-3162?c=maplin&utm_source=gcs&utm_medium=gcs_search&utm_campaign=VE00A&utm_content=Automotive+Kits
Jonathan Butler
PostPosted: Thu Aug 30, 2012 6:20 pm    Post subject: Reply with quote
After handing over several notes of the realm, the freshly-skimmed spare head for the truck returned home today.
PostPosted: Fri Aug 31, 2012 12:58 am    Post subject: Reply with quote
Thanks for the interesting link, I like the sound of the intermittent wiper kit linked off the same page even more though! I have a pushbutton fitted to give a single wipe, but that gets to be a real drag on drizzly Welsh days that are neither one thing or the other - worth investigating further, methinks Smile
