URGENT HELP PLEASE - MORRIS VAN
Bayliss Thomas
PostPosted: Fri Aug 31, 2012 10:18 am    Post subject: URGENT HELP PLEASE - MORRIS VAN Reply with quote
Folks, my pal has a 1967 Morris LDM30W van, the engine has suddenly expired and fears it has siezed. It is very likely that a replacement engine will be required.
Any local contacts in the vicinity of Diss/Stowmarket/Ipswich/ Bury St Edmunds areas who would be able to repair the engine urgently.
PostPosted: Fri Aug 31, 2012 10:23 am    Post subject: Reply with quote
Would your friend not consider unseizing and repairing his existing engine?
PostPosted: Fri Aug 31, 2012 10:27 am    Post subject: Reply with quote
I would strip it down. Maybe its dropped a valve. We had LD vans in the Post Office and never had any serious engine problems.
The Clan Chieftain
PostPosted: Fri Aug 31, 2012 11:33 am    Post subject: Reply with quote
Don't forget that even if all goes to plan stripping, possibly machining and rebuilding an engine takes time, which could be of the essence.
Bayliss Thomas
PostPosted: Wed Sep 05, 2012 3:43 pm    Post subject: Reply with quote
Looks like the engine is beyond sensible repair apparently. I have not seen it myself but they say a REPLACEMENT ENGINEis sought.
So a 2.2lt engine from a Austin A70 or Gypsy. Leads please.
Churchill Johnson
PostPosted: Wed Sep 05, 2012 8:12 pm    Post subject: Reply with quote
I think if you fit a much more powerful engine the next problem will be the rear axle.
Mog
PostPosted: Thu Sep 06, 2012 8:30 am    Post subject: Reply with quote
One problem leads to another.....
RUSTON
PostPosted: Thu Sep 06, 2012 8:00 pm    Post subject: Reply with quote
The 2.2 was fitted to the Gypsy, the FGK30/S200, some FX3 and 4's amongst other vehicles as well as the LD range so I would imagine that there are some still around. One of the best power units used by BMC at that time, I must have rebuilt dozens of them over the years both in petrol and diesel form.
Pete.
Measure twice...cut once!
michael1703
PostPosted: Thu Sep 06, 2012 10:30 pm    Post subject: Reply with quote
what is 'sensible repair'? whats actually wrong?
crank and shells cheap,you can get rings new,thorntons will have pistons
I know a few guys locally into their old commercials, I'll ask around
off the top of my head, there was a guy in diss that had ice cream vans, gd sutton? theres a guy called jerry on raf bentwaters that runs these engines in ice cream vans,
try http://www.austingipsy.net/ too
