1948 Alvis TA14 dynamo charging?
cheltenham-sable
PostPosted: Tue Nov 20, 2012 8:36 pm    Post subject: 1948 Alvis TA14 dynamo charging? Reply with quote
Just out of curiousity when driving the ammeater shows a reasonable charge the top of the gauge is 20amps some times the gauge looks like its almost stuck here and evan when on tick over after been at high revs but then all of a sudden it will come back down like when its on tick over and show 0 then show about 10-15amps when driving but if i have few revs on for quite while when driving its like it goes to top of the gauge 20amps then stays there for while?
Regards Tom
PostPosted: Tue Nov 20, 2012 11:38 pm    Post subject: Reply with quote
Regulator adjustment/contacts sticking - what is the regulator model and what is car
May be a high resistance connection in the charging circuit or failing/dry battery
Not a good idea to use it like this though as may cook the battery or worse Shocked
Even 15a is too high if battery is fully charged
Rover P2
Morris Mini Traveller Mk2
PostPosted: Wed Nov 21, 2012 2:02 am    Post subject: Reply with quote
Correct, sticking points.
Disconnect the battery, fold a one pound note in half & pass it between the points to polish & clean them.
A ten bob note will work, but it takes twice as long.
Don't even think about using sandpaper or a file.
2002 MINI Cooper 'S'
PostPosted: Wed Nov 21, 2012 8:56 am    Post subject: Reply with quote
This particular fault is quite common in NOS control box's, caused by oxidation of the points over the many years the unit has sat on a shelf.
Regulator contacts are Tungsten and can be cleaned with wet and dry paper. The cut-out contacts are silver and should be cleaned as MVPeters describes Very Happy
PostPosted: Wed Nov 21, 2012 12:29 pm    Post subject: Reply with quote
Mike & Dave,
Now where are you guys going to find a Pound note nowadays? I think the Bank of Scotland is the only bank printing them and we sell them for £5 Laughing
Art
PostPosted: Wed Nov 21, 2012 2:04 pm    Post subject: Reply with quote
If you run an antique car, you're supposed to keep an antique pound note in the antique Owners Manual in the antique glove box.
If you run out of antique petrol, one antique quid will buy you plenty!
Only the Scots could print money worth five times the face value - please teach me the trick.
PostPosted: Wed Nov 21, 2012 2:17 pm    Post subject: Reply with quote
If a ten-bob note takes twice as long as a pound, perhaps the £5 a shot quid note does it five times as quickly.
I do have a couple in the glove-box; been there for ages, I thought they were worthless.
cheltenham-sable
PostPosted: Wed Nov 21, 2012 7:41 pm    Post subject: Reply with quote
Haha thanks for the replys the batterys brand new although the car has been stood for 7 years before i got it, how go i clean them? I havnt had any experience with control box's before only sealed ones on old tractors.
Regards Tom
cheltenham-sable
PostPosted: Wed Nov 21, 2012 8:30 pm    Post subject: Reply with quote
I have taken off the cover on the regulator box and can see 2 copper coild with like points on the end i take it these are what you mean? should i rub some very fine 1500 wet n dry in the gap or £5, £10 note?
Regards Tom
PostPosted: Wed Nov 21, 2012 8:42 pm    Post subject: Reply with quote
You're in the right place, Tom.
1500 w&d might be OK, just don't be aggressive.
You're cleaning/polishing the points, rather than sanding them.
Blow the dust out.
Post-decimal notes won't work on a pre-decimal regulator!
P3steve
PostPosted: Thu Dec 13, 2012 2:33 am    Post subject: Reply with quote
I’ve got exactly the same fault on my P3 Rover and I took it to an old school auto electrician chap I know who tried to clean it but its still sticking and will need a new control box.
This is the type I will need but they do others, buying new old stock could be a false economy as being in storage for a long time could create the same problem.
http://www.holden.co.uk/displayProduct.asp?pCode=RF95
