whiteshadow
Posted: Thu Jan 03, 2013 9:11 am Post subject: Annealing engine oil pipes |
| I now want to reassemble my 1933 Singer engine, which has a number of internal copper oil pipes. It would obviously be a good idea to anneal these these after 80 years, but how can that be done without all the soldered fittings (hard!?) ending up on the floor.......I really wouldn't like to have to remake!! |
Kelsham
Posted: Fri Jan 04, 2013 10:35 am Post subject: |
I had to soften some copper pipes on the engine of my 1932 BSA Trike. I heated the pipes up away from the nipples and therefore only softened part of the pipe.
If you require a better job you may have to resolder the nipples/connectors.
I expect they are silver soldered? If so a good heat source will be needed.
Regards Kels. |
Salopian
Posted: Sat Jan 05, 2013 12:59 am Post subject: |
At the risk of being shouted down (I can take it!) don't think I would bother. Never had a problem in years gone by with such pipes and there is the risk I think of forming internal scale which could cause future problems. _________________ Jonathan Butler
Kenham
Posted: Sun Jan 06, 2013 1:07 am Post subject: |
| I think I agree with Salopian, if they have lasted for80 years with no problem I would leave well alone. If you are worried it is probably easier to start again with new material. If they are silver soldered surely they will stand anealing anyway. |
whiteshadow
Posted: Sun Jan 06, 2013 10:49 pm Post subject: me also! |
That was my thoughts!
The advice from the club was to heat up and drop in water......more I think to boil out the crud in the pipes than anneal them!!
I think there is more risk in me remaking the quite complex pipes than leaving well alone! |
