Done anything in your garage lately.
Goto page Previous  1, 2
PostPosted: Thu Jan 31, 2013 9:26 am    Post subject: Reply with quote
bob2 wrote:
sounds bad Rick!!
but at least if no harm has been done to the car or anything at least you can put everything back together!!
Yeah a bit annoying, the heavy roof structure of the shelter came down on top of the Dodge trailer (nothing hurt fortunately) and missed the A40 and the green Morris.
Churchill Johnson
PostPosted: Thu Jan 31, 2013 10:39 pm    Post subject: Reply with quote
Been slowly putting up cellotex 25mm insulation board to the inside of the tinroof of my w/shp hope to stop some of that condesationstill got thedoor's and one half on door end to do.
PostPosted: Thu Jan 31, 2013 11:52 pm    Post subject: Reply with quote
I works; not had a drop of condensation in my garage since doing that.
Also, amazingly warmer for my bald head!
PostPosted: Fri Feb 01, 2013 7:50 am    Post subject: Reply with quote
I have 2 40' containers, one of them has that silver bubble wrap stuff on the ceiling and it has far less condensation in it.
PostPosted: Sat Feb 02, 2013 9:23 pm    Post subject: Reply with quote
A neighbour of mine came up with an interesting solution to the condensation problem in his unheated garage. Basically it takes the form of an inner roof - made from corrugated clear plastic sheets - fixed with screws and rubber washers to the underside of the purlins holding up the outer roof of corrugated steel sheets. At the lower end is a gutter to collect the condensation drips and a downpipe draining into a bucket (which then forms a handy supply of distilled water). Now, this inner roof is fairly close fitting all the way round except for the necessary gap around the gutter, and to be honest I never thought it would work - I figured the condensation would simply form on the plastic sheets instead and drip down as before - but it does work, and it works well.
PostPosted: Sat Feb 02, 2013 10:37 pm    Post subject: Reply with quote
Water which has come into contact with any metal cannot be considered pure enough to be distilled water. Particularly as far as lead acid batteries are concerned.
Steel roof? Bucket - is it steel?
Jim.
PostPosted: Wed Feb 13, 2013 9:56 pm    Post subject: Reply with quote
This afternoon after I came back from the MOT station with the Suzuki, I decided to label my containers and spent ages sorting out woodscrews from self tappers and washers from spring washers. Much tidier now. Cool
The Clan Chieftain
PostPosted: Fri Apr 05, 2013 10:49 pm    Post subject: Reply with quote
Today I painted the garage doors inside and out. Took me ages.
The Clan Chieftain
Page 2 of 2
