Re-engined cars
PostPosted: Sun Mar 10, 2013 12:06 pm    Post subject: Re-engined cars Reply with quote
Cars with non-original engines.
The red Spitfire had an engine from a 1300 (Toledo I think) saloon, so wasn't quite original although it had the Spit head on it.
Otherwise, apart from the blue 2.5 Spit (it was Triumph though), most of mine have had original-spec engines in them.
What re-engined cars are, or have been, owned by forum members?
PostPosted: Sun Mar 10, 2013 12:24 pm    Post subject: Reply with quote
I used to have a Corsa with a Redtop fitted. It went like stink. It used to be a 1.1.
The Clan Chieftain
PostPosted: Sun Mar 10, 2013 1:48 pm    Post subject: Reply with quote
What's a redtop? I've heard of them, but...??
PostPosted: Sun Mar 10, 2013 3:04 pm    Post subject: Reply with quote
Mine was scrapped in 1964 on account of a cracked block. When rescued from the scrap yard it received an engine a couple of years older than the car.
rjt10/4
PostPosted: Sun Mar 10, 2013 3:21 pm    Post subject: Reply with quote
1958 morris minor with a 1.6 engine from i think an oxford drove well enough though
peppiB
PostPosted: Sun Mar 10, 2013 3:27 pm    Post subject: Reply with quote
My supposed 1098 Minor runs around with a 948 engine. Much more nippy than the original. it was supposed to be a temporary measure but I like it so much I never did get around to replacing it with another 1098 (Flywheel had to be changed to allow use of the ridged 1098 gearbox)
stuchamp
PostPosted: Sun Mar 10, 2013 4:26 pm    Post subject: Reply with quote
A few of mine have had transplants over the years.
My '57 Chevy wagon originally had an in-line 6 and now has a Chevy 350 V8 from a '93 Chevy pickup.
Jason
PostPosted: Sun Mar 10, 2013 4:37 pm    Post subject: Reply with quote
rick, its the name for vauxhall's C20XE engine its a 2 litre 4 cylinder with a red cam cover, hence...'red top'
they are a very common engine modification for vauxhall corsas as they're a simple fit.
hope that helps Wink
"people with money buy a Rolls Royce, people with taste buy an Alvis".
welshrover
PostPosted: Sun Mar 10, 2013 4:52 pm    Post subject: Reply with quote
my mates running a red top in a mk1 escort in the historics at the moment. its cost him £25.000 to have built, just the engine that is, but god dont it shift Cool
PostPosted: Sun Mar 10, 2013 8:10 pm    Post subject: Reply with quote
Great engines the Red top and they are highly sought after now.
The Clan Chieftain
PostPosted: Sun Mar 10, 2013 8:59 pm    Post subject: Reply with quote
Back in the mid 70s I shoe-horned a Ford 1500 GT from a Corsair into a mk1 Midget. At the same time we fitted a rally tuned 2.5 straight six Triumph engine into a Stag belonging to my brother.
The Seven Special in my avatar is fitted with a Reliant engine.
baconsdozen
PostPosted: Sun Mar 10, 2013 10:23 pm    Post subject: Reply with quote
I put a V6 zodiac into a Mk1 SWB transit some years back.Worse than any capri in the wet but fun in a straight line.
ChrisD
PostPosted: Sun Mar 10, 2013 10:27 pm    Post subject: Reply with quote
I currently have a Sprite with a pre-crossflow Ford "L" block in it. Modified back in the early 70's. Its quite a nippy little thing!
Ellis
PostPosted: Sun Mar 10, 2013 11:51 pm    Post subject: Reply with quote
I have re-engined my 1962 Series 2a Land Rover with a 200tdi from an early Discovery and it is now a pleasure (a relative term for a Series Land Rover) to drive.
I also have a 1954 Series 1, awaiting restoration, which has a BMC 1500 cc petrol engine fitted at some time in it's past. It was a popular conversion after the 1973/74 fuel crisis, I believe, but I bet it won't pull the skin off a rice pudding. I've not driven it yet.
A friend who has recently passed away once put a Riley One Point Five engine into a Hillman Imp to enter an open class for rallying in the early 1970s! Yes, that's right - engine in the front with gearbox, propshaft and rear wheel drive. It went like the wind so he told me.
Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet
BigJohn
PostPosted: Mon Mar 11, 2013 1:37 pm    Post subject: Reply with quote
I had a series 2a LandRover in 1981, it had a Perkins 4203 with Rover P5 diffs, it would pull a house down. You also knew when you met a fellow Perkins convert by the way both your bodies shook in time with a Perkins on tickover! (or one of you had a muscular affliction)
