Bayliss Thomas
Posted: Fri Aug 31, 2012 10:18 am Post subject: URGENT HELP PLEASE - MORRIS VAN |
Folks, my pal has a 1967 Morris LDM30W van, the engine has suddenly expired and fears it has siezed. It is very likely that a replacement engine will be required.
Any local contacts in the vicinity of Diss/Stowmarket/Ipswich/ Bury St Edmunds areas who would be able to repair the engine urgently. |
Posted: Fri Aug 31, 2012 10:23 am Post subject: |
Would your friend not consider unseizing and repairing his existing engine?
Posted: Fri Aug 31, 2012 10:27 am Post subject: |
I would strip it down. Maybe its dropped a valve. We had LD vans in the Post Office and never had any serious engine problems. _________________ The Clan Chieftain |
Posted: Fri Aug 31, 2012 11:33 am Post subject: |
| Don't forget that even if all goes to plan stripping, possibly machining and rebuilding an engine takes time, which could be of the essence. |
Bayliss Thomas
Posted: Wed Sep 05, 2012 3:43 pm Post subject: |
Looks like the engine is beyond sensible repair apparently. I have not seen it myself but they say a REPLACEMENT ENGINEis sought.
So a 2.2lt engine from a Austin A70 or Gypsy. Leads please. |
Churchill Johnson
Posted: Wed Sep 05, 2012 8:12 pm Post subject: |
| I think if you fit a much more powerful engine the next problem will be the rear axle. |
Mog
Posted: Thu Sep 06, 2012 8:30 am Post subject: |
| One problem leads to another..... |
RUSTON
Posted: Thu Sep 06, 2012 8:00 pm Post subject: |
The 2.2 was fitted to the Gypsy, the FGK30/S200, some FX3 and 4's amongst other vehicles as well as the LD range so I would imagine that there are some still around. One of the best power units used by BMC at that time, I must have rebuilt dozens of them over the years both in petrol and diesel form.
Pete. _________________ Measure twice...cut once! |
michael1703
Posted: Thu Sep 06, 2012 10:30 pm Post subject: |
what is 'sensible repair'? whats actually wrong?
crank and shells cheap,you can get rings new,thorntons will have pistons
I know a few guys locally into their old commercials, I'll ask around
off the top of my head, there was a guy in diss that had ice cream vans, gd sutton? theres a guy called jerry on raf bentwaters that runs these engines in ice cream vans,
try http://www.austingipsy.net/ too |
