DELETED
DELETED
PostPosted: Tue Nov 20, 2012 8:49 pm    Post subject: primer Reply with quote
DELETED
Desert Fox
PostPosted: Fri May 24, 2013 10:03 am    Post subject: Re: primer Reply with quote
wilson294 wrote:
Use 2 pack high build epoxy its 10 quid a litre its very good very sticky and it goes on bare metal without the kneed for etch primer
All non-ferrous metals require an etch primer unless the epoxy is specifically designed for use without etch primer. If not, the paint adhesion will fail.
