35mm Slide & Film Scanner
PostPosted: Mon Dec 31, 2012 3:09 pm    Post subject: 35mm Slide & Film Scanner Reply with quote
Whist picking up some components in Maplin yesterday, I spotted THIS film & slide scanner, on offer at £14.99. If like me you have loads of stuff on 35mm, I thought I'd give it a go, and I think its ok Very Happy
It comes with some colour/ red eye/ etc correcting software and is simple and quick to use. Feels a bit cheap for the £60 non sale asking price! but at £14.99 one can't complain.
Scanned this negative, taken about 18 years ago at Oulton Park.
PostPosted: Mon Dec 31, 2012 6:28 pm    Post subject: Reply with quote
Neat! I've an adapter for my flatbed scanner which does negatives, takes a little while to go through them though, yours looks quicker to use.
I'm just test driving a USB record player we picked up at Aldi, I currently have Shelsley Walsh 1947 playing, recorded just now from a 78 rpm Cool
Inglewood
PostPosted: Mon Dec 31, 2012 7:41 pm    Post subject: Reply with quote
I use a Veho scanner, much the same as the Maplin one. Really happy with the results. I use a photo editor to bring back the colour.
PostPosted: Mon Dec 31, 2012 7:50 pm    Post subject: Reply with quote
Another way to do slides.
If you have digital SLR use a slide copier such as used to be fitted instead of the lens on an SLR when copying slides or getting a negative film from slides.
PostPosted: Mon Dec 31, 2012 8:07 pm    Post subject: Reply with quote
Hi Dave,
Approximately how long does it take to scan one frame?
Does it autofocus on a glass mounted slide?
Thanks,
PostPosted: Mon Dec 31, 2012 8:12 pm    Post subject: Reply with quote
At that price I wouldn't argue. I bought a sophisticated scanner about 10 years ago and did my whole collection of slides and negatives. The difference with yours is the size of the scan at 5 megapixels it's not huge. Nothing wrong with that scan though and the colour wash-out might not be the scanner but the negative. In the days of lab processing they didn't always get it perfect. As said previously, you can easily put that right.
PostPosted: Mon Dec 31, 2012 8:40 pm    Post subject: Reply with quote
Hi Rick, its amazing what Aldi sell, I bought a box of "O" rings from them a couple of years ago for a really silly price!
peter scott wrote:
Hi Dave,
Thanks,
Hi Peter, it takes about 10 seconds to scan, the negative or slide fits into a carrier (both are supplied), its fixed focus. One downside of it is that 35mm negatives fit into a notch that aligns with the holes in the film, if this doesn't align with how the film went through the camera, you can loose the edge of a picture and have a slight black bar on the other side, this is the case with the picture I posted, I plan to modify the carrier to eliminate this.
Hi Colwyn500, I bought a Minolta film scanner about 10 years ago, that could scan a 35mm negative to about 40 MP, I never found I needed that size, and it has a SCSI connection,takes 1 min to scan, after the pre scan, non of my current computers have a SCSI connection!. My Minolta scanner is undoubtedly better built and better quality, but this thing plugs in to a USB, and will do most of what I need at a tiny fraction of the price. I do intend to get a SCSI-USB converter for the Minolta, but everything I need to post on this forum from 35mm will be from the cheap scanner.
Happy new year
all the best
PostPosted: Mon Dec 31, 2012 10:18 pm    Post subject: Reply with quote
Thanks Dave.
JohnDale
PostPosted: Wed Jan 02, 2013 1:27 pm    Post subject: Reply with quote
Hi Dave, I have an adapter lens which fits my Olympus camera for copying slides but it's a slow process. Will the Maplin copier accept slides in plastic mounts or just the cardboard ones? My local store has five in stock on offer so I would purchase one if they'll do the job,cheers,JD.
1976 Ford Granada Ghia.
PostPosted: Wed Jan 02, 2013 3:04 pm    Post subject: Reply with quote
Hi John
Sorry I don't use slides so not sure, the internal dimensions of the carriers slide locator are 50.25mm x 50.25mm x 2.5mm if that helps?
JohnDale
PostPosted: Wed Jan 02, 2013 5:13 pm    Post subject: Reply with quote
Hi Dave, thanks for that. The square size is 50mm & the majority look about 2.5mm but I have some of a different type which look like 3mm. I'll take a couple of slides with me & persuade them to open one of the units to check,kind regards,JD.
JohnDale
PostPosted: Fri Jan 04, 2013 5:47 pm    Post subject: Reply with quote
Hi Dave,took a couple of differently cased slides to Maplin & there was no problem trying them in the slide holder - they fitted OK so I bought one.
Great piece of kit,very quick. Thanks for the info,cheers,JD.
PostPosted: Fri Jan 04, 2013 7:22 pm    Post subject: Reply with quote
Dave, I thought about buying one. But although they had several models and all reasonably priced, they had none at that "giveaway"price. I will keep popping in though, thanks for the suggestion.
Brian M
PostPosted: Fri Jan 04, 2013 8:47 pm    Post subject: Reply with quote
I have been looking at boxes and boxes of slides taken by my father in the 1960's wanting to find a way of getting them digital. Bought the Maplin one yesterday for £14.99 and have tested it on 20 or so slides and I am pleased with the results.
UKdave - thanks for the tip.
Brian
Geoffp
PostPosted: Fri Jan 04, 2013 10:32 pm    Post subject: Reply with quote
Another 'thank you' for the tip, Dave. I bought on today, all I have to do know is sort through my slide collection and see if I have actually got any which are worth copying Smile
Cheers,
Geoff
