J B Weld
PostPosted: Sat Jan 19, 2013 11:49 am    Post subject: J B Weld Reply with quote
I was talking to model engineer in the pub yesterday, about attaching some "fake" self clinching studs. I was talking about spot welding them to a bracket, much to my surprise (given everything he makes is a precision belt and braces job) he suggested J B Weld (epoxy glue) for attaching non critical low load metal to metal Shocked
Anyone else used it?
D4B
PostPosted: Sat Jan 19, 2013 12:29 pm    Post subject: Reply with quote
Yes I have used it, I even drilled and tapped a thread in it!!
Good stuff
http://www.ebay.co.uk/itm/J-B-Weld-Industrial-Strength-Adhesive-JB-Cold-Auto-Weld-Carded-/261131747799?pt=UK_Crafts_Cardmaking_Scrapbooking_Glue_Tape_EH&hash=item3cccaa41d7
PostPosted: Sat Jan 19, 2013 1:21 pm    Post subject: Reply with quote
I used it to repair a porous backplate on a Range Rover diff, the backplate is not the separate bolt on type and a complete new casing would have been required, so the JB Weld worked wonders
ROVER
One of Britain's Fine Cars
PostPosted: Sat Jan 19, 2013 2:01 pm    Post subject: Reply with quote
I used "JB Weld" as a "temporary" repair to a frost crack in my Austin Ten engine block. It's a common problem and the text-book solution is metal stitching.
The adhesive "creeps" noticeably and was tricky on a vertical surface. But it sets very smoothly and although I didn't paint it over, it's hard to tell it's there at first glance. I will report back in a few years to say if it's still working; I rather think it will be!
PostPosted: Sat Jan 19, 2013 2:44 pm    Post subject: Reply with quote
I heard JB Weld was good to an Astonishing PSI rating, anyone know what it is?
D4B
PostPosted: Sat Jan 19, 2013 5:52 pm    Post subject: Reply with quote
Found on their website that the professional version will withstand
3960 PSI......... here...
http://www.jbweld.com/product/j-b-pro/
not sure about the standard one..... here's their home page
