alapimba
Posted: Mon Jun 10, 2013 2:25 pm Post subject: Steering wheel play On Ford model y |
Hello
My car failed the portuguese equivalent mot due to steering wheel play (45°- 1/ .
The steering box is of the worm And nut type And the nut is not new anymore.. Thats the reason for the play On the steering wheel .
Theres any trick to solve this as i can find a new nut neither no one to rebuild it. I filled the box with grease but the gap Didnt reduced..
Regards |
alapimba
Posted: Mon Jun 10, 2013 2:41 pm Post subject: |
| Originaly no theres no adjust nut or screw. All gaps inside the box were eliminated, except the one On the nut |
Posted: Sun Jun 16, 2013 8:07 am Post subject: |
A very small amount of play gets magnified by the gearing to quite a lot of steering wheel movement. I found that most of the play on mine was not on the thread but where the peg interfaces with the nut. You can take the peg out and turn it through 90 degrees and that removes quite a lot of play.
alapimba
Posted: Sun Jun 16, 2013 9:08 am Post subject: |
Hello
What os the peg? |
alapimba
Posted: Mon Jun 17, 2013 12:08 am Post subject: |
Thanks for the diagram
In my case we checked all that parts and they were ok.
The problem os really On the nut thread |
